Anyone broken one? This is for my 95 4t60e
Is Their a Stronger Flex Plate availabl for 4t60e?
Tags: None
I'm using an 05 flex plate from a Impala, they are suposedly light weight, but same strength... I have yet to hear some one break one. I've only dynoed at 206hp 238tq at the wheels but I know I have more than that now.
L67's break them all the time once they start dipping around 300whp+. Which is why i'm searching for a stronger one.
If THAT'S what you're looking for, ZZP sells a billet flex plate. I think you have to use a 4T65E torque convertor instead of the 4T65E-HD unit.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Interesting. So it should be backwards compatible.Originally posted by Dave96z34 View Postim runing my 4t60e plate with my 4t65e
Doesn't a 95 4t60e have a 245mm torque converter?
I contacted ZZP and their flex plate will fit perfectly.
Stock flex plates can start to break around the 300whp+ point. Alot of other factors play into flexplate breakage.
I think i'll stay with my stock one instead of $400 :O
Got a part # for that flex plate?Originally posted by 3400-95-Modified View PostI'm using an 05 flex plate from a Impala, they are suposedly light weight, but same strength... I have yet to hear some one break one. I've only dynoed at 206hp 238tq at the wheels but I know I have more than that now.
