4t65e swap
  • thepipes
    • Aug 2007
    • 4
    4t65e swap
    I have a 97 Olds Sil that has a 4t60e in it. I have the engine out to rebuild. Can I bolt up a 4t65e without any problems? If not, should I do anything to the 4t60e before I re-install it? It has 60k on it since rebuild. Thanks,
    Dan
  • sharkey
    • Jun 2004
    • 2061
    the 4t65e will bolt up without issues, the axles will fit, and everything will go together without issues. as for the wiring and controll, its drasticly different, you would have to swap a wiring harness/pcm from a 4t65e car
