What do you guys think about the Lucus Trans Treatment?? A Guy on another forum told me to drain my oil, replace the filter and add just regular tranny oil without Lucus.. He said that the Lucus will destory My Tranny.. What do You guys think of this stuff?
Lucus Trans Treatment.. What U Think?
Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built carTags: None
this goes for any additive, but what these treatments are designed to do is swell the rubber seals up so they will get a better seal in a worn transmission to firm up shifts and stop leaks. they can work for a short time, however it also causes the valve body gaskets to swell up and it can cause small holes to be blocked off and cause big problems. it also causes a lot of grief when overhauling the transmission cause it turns all the gaskets to a glue like paste.
so what do u say?? should i flush the system?? I am using it in my 89 TGP with 105,231 miles.. i would think with 8 quarts of ATF and 24 oz. of treatment to make 9 quarts i think it is very well dilluted.. I ended up putting in 6 quarts of ATF and 22 oz. of Treatment in my car. It was just a filter and fluid change. so thats 2 quarts of the old still in there.Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
is the transmission acting up??? if not, no reason to put the stuff in there.
the 440t4/4t60e holds 10-12L of fluid. a pan drop will drain about 6L out of it, flushing is the only way ot do it all. however if the fluid was in ok shape when drained out, flushing isnt needed.
Don't use Lucas Products they don't do anything. All those displays at auto zone are garbage. If you use too much of this stuff in your tranny or if you use the engine treatment it will cause the oil viscosity to thin out and what you will end up with is tranny fluid that has the viscosity of water not good. I've tryed it in several different cars this stuff is S%%T. It will cause the engine oil and the tranny fluid to foam up with will thin out your oil and tranny fluid.
I just added 1 bottle of the trans treatment to the tranny.. First time used in the tranny.. will it be ok?Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
lol
Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
