I am trying to finish up my project. A truck I bought without a motor. The new motor is mounted, trannny is connected. I just need to run tranny cooler lines. I can't find them any where' even from the dealer. I was able to run some 5\16 brake line. I found that where the crossmember mounts does not leave me much room to attach to the two lines are coming down at about a 45 degree angle from the transmission. I tried to find a 45 degree adapter, but all the ones from Summit are either NPT or AN. The brake lines are SAE. I can not find SAE 45 degree inverted flare to fit in the tight space on top of the cross member. Any help, advice, or correction would be greatly appreciated.
