4T60 vs 4T60-E parts interchange
  • patgizz
    The Plaid Bandit
    • 1071
    say one has a bad 4T60 that they plan to rebuild. like in my 1990 turbo grand prix.
    and this person also has a 1993 4T60-E that has a 3.73 final drive and 3,000 stall converter.
    is the 3.73 stuff (what all is needed anyway?) and the converter backwards compatible to the earlier 4T60/440-T4?
    are there any other items of interest in the newer trans that are considered a strength upgrade for the earlier unit?
  • gpse3400
    • 1460
    '93 and and eariler TCs are compatible between transmissions. To make a 440-t4 3.33 to a 3.73 you need the the sprockets from the '93(3.4 tdc). get a new chain while you are at it.
    How you get a 3.73 overall fdr
    Wcar 2.8/3.1 440t4 3.33 to 3.73
    3.4tdc drive sprockets and original FDR
    3.4tdc 4t60e 3.43 to 3.73
    original drive sprockets and W -car 2.8/3.1 440t4 or 4t60e FDR
    the rest of the internal parts are basically all the same except for some parts at the foward/1-2 band area and of course the valve body and case.
    Lorenzo
    • mfewtrail
      ~600hp worth of 3.1's
      • 170
      Pat, there's another comparison related post over on the TGPForums if you want to take a look at it. I believe it had pictures comparing just about every part of a naturally aspirated 4T60 vs. a 60-E transaxle(also a 65-E).
      Matt F.
      TGP 1/4 mile times
      http://photobucket.com/albums/y33/mfewtrail/
      1990 TGP Coupe VIN Database
      • patgizz
        The Plaid Bandit
        • 1071
        cool stuff i'll check that out.
        everywhere i look i can't find anything clutch pack wise for the 4t60 that i want to use. i know i will cook a stock replacement clutch pack setup in short order with where i'm going with this car. my normal auto trans rebuild supplier doesn't differentiate the turbo vs n/a nor do they carry any sort of performance frictions for the clutch packs.
        i am going to build the trans myself so i can afford an LSD
        • mfewtrail
          • 170
          Oops, I was mistaken. The comparison was of a 4T60 vs. 3T40 vs. 4T65-E.
          I sent you a PM by the way Pat.
          Matt F.
          TGP 1/4 mile times
