Help Building A 3.73
  • 95Grand-Am
    • 268
    Will a 4T60-E code 6CUW out of a Grand-Am with a 2.4L fit into a 97 Grand-am with a 3100. Then if I take the differenial out of the 3100 trans and put it into the 6CUW trans it should give me a 3.73. Are the 2.4L 4t60-E transmissions built the strong as the 3100's? DO the bell housings have the same bolt pattern?
  • sharkey
    • Jun 2004
    • 2061
    the bellhousing bolt pattern is different. also the 4 cyl version will be built a little weaker.
    • 95Grand-Am
      • 268
      Thanks Sharkey, I 'll have to keep looking for the right trans.
      • Azrael
        Accelerating uphill in OD
        • Apr 2005
        • 763
        The 95 Grand Prix GTP's had a 3.43 FDR 4t60-E with the 3.4 DOHC. You'd have to find another diff to get it up to 3.73 though.
        1995 Grand Am SE
        • z34phoenix
          • Jun 2005
          • 469
          yep also the 95-96 Z34s i had the right trany they just grabed the right diff for me when they did my rebuild. im very happy with my 3.73's
          • torq455
            If I only had money!!!
            • 1615
            z34phoenix, what rpm do you turn at 65mph?
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
