4t45-X type?
  • cwahl
    1 Quick Bu
    • Oct 2007
    • 31
    4t45-X type?
    I never actually saw the car that my motor and tranny were pulled out of and supposedly it was out of a 2005 grand am gt (unit was brand spanking new and had 0 deposits on the rebuild).
    I am having a problem finding out what type of 4t45 it is. I have tried copying PCM tables for a 04 and a 00 grand am gt and my pcm is flashing that I have the incorrect gear ratios. I have also tried a 00 SE to no avail.
    Is there any number anywhere cast onto the trans that I can use to determine what type of trans i have (obviously its not the old 4t40 or the malibu stock pcm tables would work)?
    Any help on this would be SUPER ! :P
    • 9190
    There should be a tag on the back of the tranny that has 4 letters on it. Get those letters and you should be able to cross-reference something.
    • El_Diablo
      STFUniversity
      • 917
      are you flashing with a 3.29 gear ratio? are you sure its a gt trans? they might have tried to just pass along a 4t40 or 45 3.05 trans as a gt trans....
      did you see the car it came out of? did it have the mn5 rpo? i honestly dont see a reason why modified 4t40 tables wouldn't work as long as you satisfied all of the parameters as far as listing the correct gear ratios
      • cwahl
        1 Quick Bu
        • Oct 2007
        • 31
        The problem is that the tables change EVERY year. i did find a 05 gt on here and will flash it with that tonight. I need to check that sticker on that trans. I can tell its not a 4t40 because my stock malibu file wont work on it.
        • El_Diablo
          STFUniversity
          • 917
          wow, i cant believe i missed you saying you didn't see the car, sorry, lol
          • cwahl
            1 Quick Bu
            • Oct 2007
            • 31
            wow... i am glad I found this board
            Someone had posted an 05 grand am gt bin file..
            i copied those transmission tables over and 0 error codes yet... they didnt lie to me :P
            • El_Diablo
              STFUniversity
              • 917
              can you maybe do me a favor and send me a few of those bin files? you have a pm
