T5 vs T56
  • Fedaykin
    • Aug 2005
    • 95
    T5 vs T56
    I got a 3.4 ironhead and a T5, I am toying with the idea of a T56 in its place. I assume the T56 would bolt up to the 3.4 the same as a T5 would... is the bellhousing larger or are there any differences that would make this impossible?
    • 9191
    -- Moved to the proper section. --
    • Fedaykin
      • Aug 2005
      • 95
      thanks
      • BMC
        • 146
        I believe the GM bellhousings are intrical. (sp?)
        The other units that I know of have a different bolt pattern, but I bet there is a way, although these are not needed on the 3.4L... More of a bragging right item then anything.
        -BMC.
        MG & MGB V6 + V8 Engine Conversion Shop
        1982 Chevrolet S10 long box with another L32 SFI!
        1980 MGB with Camaro L32 3.4L SFI V6
        2000 Venture 3400 (for her)
        Spitfire L32 3.4L
        "Experimentals"
        and more conversions all the time.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          I am not certain but the T56 appears to have a similar trans pattern to the Aisin transmission family found in the CTS, Solstice and Colorado. If this is true you can use the bellhousing found in the CTS with a 3.6L to mount it. But that only gets you so far. I am not sure on the input shaft stick out or pilot bearing size.
          You could look into using the Aisin AY6 6 speed but I don't like the 4.15 to 2.33 1-2 shift. Otherwise I would seriously be considering one for my truck.
          • Fedaykin
            • Aug 2005
            • 95
            Yeah, I just bought a shifter on ebay, the wanker thought it was for a t5 and i didnt look close enough... turns out its for a t56. anyone need one?
            B&M t56 ripper.
            thanks Geoff
