limited slip diffs
  • montess408
    • May 2006
    • 391
    limited slip diffs
    hey i am looking at getting a lsd unit for my trans is the phantom grip any good ? i was looking at a team green today but i dont think he makes them for my trans.and i know that the E.P is the best but i dont really want to spend that kind of money on the trans. so is the phamtom grip good enuf for a mild project or is it a POS unit ?
  • 3100 MPFI
    • 1522
    People over on the Fiero board have had the phantom grip blow up on them.
    http://www.fiero.nl/forum/Forum2/HTML/082235.html
    Granted, it is the GETRAG's that blow up, but seeing some of the carnage pics, it makes me hesitant to trust them.
    Taylor
    1998 Lincoln Mark VIII
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      mpracing.org/store sells LSDS through EP. Be warned that you could be waiting for up to 6 months for a LSD. If you order a LSD through mpraicng you should it sooner because both you and mpracing will be asking for the lsd to be complete in a timely manner.
      The delay is because Jeff is working the shop by himself. Until he gets help then the shop should speed up.
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
        I've got the team green insert in my 282, i'm not overly impressed but it did help with the torque steer.
        I'll pull it out soon and inspect for damage, i've got a little over 1K miles on it.
        • blackbombshell95
          Kaiō-ken X 10
          • Jun 2004
          • 1386
          MY lsd/trans build from EP should arrive by the first of december. I expect great things. I also found that dynotech also sells EP lsds which must mean that they are pretty good.
          • 19Cutlass94
            • Apr 2005
            • 770
            Be sure to let us know how that tranny works out! Im interested in buying stuff from them!
            3400/Getrag 284 5spd
            350/NV3500 5spd
            2014 Chevrolet Malibu LS
              the EP ones are pretty much the same design that i've seen in stock GM LSD rear ends and Ford as well..
              kind of a tried and true design, Maybe someday i'll pick one up...
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                I'll let you know. If you order a LSD order through mpracing.org/store
                If all goes well it will be running by the 2nd week of December.
                LSD. 3.73 gears. 3k stall. EP shift kit. All new
                • loner666
                  • Oct 2006
                  • 435
                  i only see it for the 4t45e and 4t40e..they use the same diff as the 4t60e?
                  Best 1/4mile ET - 12.9
                  Best 1/4mile MPH - 111
                  1997 Ford Ranger Splash
                  Daily Driver
                  • LeftVentricle
                    Right aorta
                    • Oct 2005
                    • 507
                    Wouldn't count on it. 40 and 45 are physically smaller than 60, iirc.
                    • blackbombshell95
                      Kaiō-ken X 10
                      • Jun 2004
                      • 1386
                      The diffs are different. Contact Mark(mpracing owner) and he should be able to get it for you.
                      I should add that Mark is a great guy and a great seller. I've made 2 orders from him and they went smooth as possible.
