i have a question
  • camaro1991
    • Oct 2007
    • 33
    i have a question
    ok this is my question
    what is the difference between 7.5 rearend and a 7.625??
    i have 4.10 gears for a 7.5
    will it fit or what?
  • sharkey
    • Jun 2004
    • 2061
    the difference is the ring gear is 1/8" bigger. no the gears will not swap over.
    • camaro1991
      • Oct 2007
      • 33
      damn that sux
      • latemodelnewbee
        • Jun 2007
        • 227
        The gears will swap over between the two, I have the 7.625" gears in my monza with 7.5" housing. In a F body, S10, or full size car its no problem they just bolt right in (properly set-up of course don't just throw the gears in and go), lot easier than my monza. Monzas and vegas use 7.5" that has a smaller pinion bearing the one closest to gear I had to turn it down to accept a H body bearing but this is a H body thing only.
        68 El camino 454 speed muncie 3.90 posi 12 bolt,
        80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
        60 Impala 2 door hardtop L79-327 T56 4.11 posi.
        83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
        91 Z34 now has a hm284. and belly pan in the works
