Whats the easiest way to get the passenger axle out? I untorque the axle, slide off the wheel hub and now what? Remove the tie rod and lower balljoint? should that be it? Thanks a lot guys its cold out here.
Easiest way to remove Axle 2000 W-body
Tags: None
Just undo the lower ball joint. The axle stub should be able to come free of the hub with the tie rod end still attached.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
