Strange grrrrrrrrrinding noise
  • Coyote_Rage
    Wrench Jockey
    • Mar 2007
    • 115
    4T60e stamped on the pan in a 91 GP.
    Upon hard acceleration I get a very audible grinding/grating noise. Almost like a chain being dragged across sheetmetal. I have also noticed hard shifting when I am at or near WOT.
    This trans has about 140K on it, and when I bought the car last year the trans fluid was brown, indicating lack of regular maint. I am prepared to buy a trans if I need to, but what in the hell is that noise?
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    go manual. it is a PITA but worth it.
    • IanSzgatti
      • Oct 2006
      • 519
      maybe it's lack of pressure causing incomplete engagement. planetary gearset worn out? pressure solenoid on it's way...
      • gpse3400
        • 1460
        better check the fluid. if it has a hint of purple and or black, the trans is done.
        Lorenzo
        • PCGUY112887
          • Feb 2006
          • 1067
          4T60E in a 91? I thought they started 92-93?
          SpudFiles
          Theopia
          Enjoy life online.
          • Coyote_Rage
            Wrench Jockey
            • Mar 2007
            • 115
            I thought they did to, but this one hase 4t60E stamped on the pan
            • DEI37
              • Jan 2004
              • 516
              Is it a 3.4 or a 3.1?
              • Coyote_Rage
                Wrench Jockey
                • Mar 2007
                • 115
                3.4L
                • sharkey
                  • Jun 2004
                  • 2061
                  thats why. 91 was the first year for the 4t60e, only behind the 3.4l tdc. between 92 and 94 the 440t4/4t60 was phased out and the 4t60e took its place.
                  • TurboGTU
                    • 453
                    Its probly the plastic thrust washer on the drive chain sproket that has seen its better days.
                    • nixtux
                      • Nov 2007
                      • 282
                      when you idle can you feel a shudder every 15-30 seconds?
                      with the shudder comes a crazy quiet noise but not quite grinding?
                      I can't explain the sound but my Cutlass had a similar issue and 20 miles later momentum was taking me to my garage (thankfully I was able to make it since no gear would work.)
                      Ironically the idle was the biggest thing I noticed. But during traffic merges and whatnot it was like the car would shudder somewhat and it sounded kind of like grinding but not exactly.
