4T60-e shift Kit?
  • AWeb80
    W-body RSTB Maker
    • Feb 2004
    • 392
    #31
    wow, chirping is pretty cool.
    I'll deff do the double springs then in the 1-2....and then maybe 3 of the door hinge bushings.
    • AWeb80
      W-body RSTB Maker
      • Feb 2004
      • 392
      #32
      btw, I'll be calling the 2 local dealerships here and see if they have springs and also a few local tranny shops.
      They are called the "modulator springs" right
        #33
        Accumulator springs. Specifically 2 sets of the 2-3 springs.
        • gpse3400
          • 1460
          #34
          when I shimmed my acumulators with the door hinge bushings I made it so my pistons did not move at all(3 bushings). I still had the springa in there for good measure, with the 1-2 bore have 2-3 doubles as well. With the vacuum modulator adjusted proper it shifted frim but comfortable. WOT is was a tire chirping champ....Unfortunatly wheel hop is something that takes away from the fun...
          Lorenzo
          • AWeb80
            W-body RSTB Maker
            • Feb 2004
            • 392
            #35
            well, there goes it....
            3 bushings, new springs, and need to find a modulator....
            Thanks guys...now to find the dang springs....
              I'm thinking the only luck I'll get for springs is the yard...
              But we'll see.
              • AWeb80
                W-body RSTB Maker
                • Feb 2004
                • 392
                #37
                Well, I Got Ahold Of A Local Shop. The Guy Was Reluctant To Help. I'm Stopping In Tonight To Make Sure They Have Them. If So, I'll Tell Him He Has More Buyers. Hence, You Guys. I'll Keep You Updated Via My Phone.
                  Nice, I would need two sets of the 2-3 and if he has them one set of the 3-4 for safe measure since those break too...
                  Don't worry about those for yourself because those are on the backside of the channel plate and if your not doing a full rebuild you wont have access to them.
                    Nevermind for me, I just got back from the stealership and I got my 3.5 LIMG set, and also ordered 2 sets of the 2-3 springs and two springs that I saw for the 3-4 that were listed... I'm not sure if I need both or just one, I can't remember. BUT since they were all in TN, I had to get overnight shipping on them so I can get this trans finished on time.
                    I'll have the GM part numbers tomorrow and post them up here.
                    • AWeb80
                      W-body RSTB Maker
                      • Feb 2004
                      • 392
                      #40
                      dang....you should have ordered them for me....
                      how much were they?
                      P#'s would be great too.....the stealership around here doesn't have them.
                      I NEED THESE BY FRIDAY
                      • AWeb80
                        W-body RSTB Maker
                        • Feb 2004
                        • 392
                        #41
                        also found this site...couldn't find anything.....you guys see anything?
                          the 2-3 set was like 11 for outer, and 6 or 7 for the inner and I had those ordered overnight additional 20 bux or so... Your stealership should be able to get them for you if you have PN. They are ordering mine from the TN warehouse.
                          If you want some I can order them for you tomorrow but they would be in Wednesday, and then I would have to get them to you... and NE is a little ways away from me, your closer to TN, so you should be able to get them for Friday if you have the numbers.
                          And no bulkpart doesn't have them, I checked there already.
                          • AWeb80
                            W-body RSTB Maker
                            • Feb 2004
                            • 392
                            #43
                            How About Just Shipping Them Right To Me Instead Of Having Them Go To The Dealership First? I'll Let You Know Tonight What I Find Out At The Local Trans Shop.
                              I don't think they can do that...
                              I'll have PN's by tomorrow afternoon.
                              • AWeb80
                                W-body RSTB Maker
                                • Feb 2004
                                • 392
                                #45
                                Ok. I'll Just Over Night Them From My Dealer. Thanks
