4t60e Oh Joy
  • loner666
    • Oct 2006
    • 435
    come on guys..someone must have some idea..hes some symptoms for you
    engine is under a constant load and will not go above 3k (around the convertor stall)
    P, R, N , OD, D and L doesnt matter which one
    N will allow movement both ways running or not
    car off in D it rolls both ways
    car running in D it rolls forward but not back
    car running in R it locks in place
    Best 1/4mile ET - 12.9
    Best 1/4mile MPH - 111
    1997 Ford Ranger Splash
    Daily Driver
    • gpse3400
      • 1460
      R and not moving would suggest Selector cable adjustment. About what is happening at 3000, you description seems alittle vague....
      The engine is under a constant load(other than itself and accessories) regardless of selector postion?
      Lorenzo
      • loner666
        • Oct 2006
        • 435
        Selector cable is fine. The car doesnt not move on it own no matter what
        Put your car in drive. Push the brake and gas. Thats what my car is doing in Park. If you want Ill get a video of it later this week if that helps. It acts like its in gear but I am able to push the car around. Kind of like preloading to launch the car at the track
        One trans guy suggested that the clutches welded together somehow but if thats the case I shouldnt be able to move the car while its running in gear
        Daily Driver
        • gpse3400
          • 1460
          Yeah if you can. I can help you better that way. This is all very strange...
          Lorenzo
          • loner666
            • Oct 2006
            • 435
            Yes it is. Everytime something happens with my car its really hard to figure out. Either way its getting another trans when I get the money for it but it would be nice to know whats wrong with this one
            I get a vid as soon as i can
            Daily Driver
            • AWeb80
              W-body RSTB Maker
              • Feb 2004
              • 392
              #21
              I'll Take The Accum Housing Off Your Hands....That Is If It Is A 4AFW Trans.
              • loner666
                • Oct 2006
                • 435
                #22
                I dont remember what the code is on this trans. I just remember it came from a 98 lumina. I have no idea when Ill have this one pulled. Need to get money together for a replacement and depending what I figure out when its out I may rebuild it stronger
                Daily Driver
                • Z26-T
                  • Apr 2008
                  • 486
                  #23
                  so you power brake it a lot? were you power braking it when you were at the light? I've seen this a few times at the track with people power braking, you roll the sprag over in the torque converter. So that's my bet . If the fluid doesnt smell really burnt, id doubt the clutches are burnt enough for it to not work.
                  • loner666
                    • Oct 2006
                    • 435
                    #24
                    This trans has very little power braking. I only do that at the track and this trans has only seen 3passes. At the time it died I was slowing down for a light after getting off the highway doing around 80-85mph if that matters
                    Daily Driver
