Synthetic trans fluid
  • Fuel
    • Sep 2007
    • 29
    Ok to run synthetic
    trans fluid in a new
    (reman) PS rack?
    It's a 3100.
  • TurboGTU
    • 453
    its fine.
    • Alxsmt
      that one guy
      • Feb 2007
      • 725
      trans fluid instead of power steering fluid?
        • 9191
        From AllData:
        "Automatic transmission fluid should not be used in these power steering systems. ATF is not compatible with the seals and hoses used in this system and will eventually cause damage. Also, power steering fluid must withstand very high pressure (about 1400 psi), whereas transmission fluid does not have the need to operate at these pressures. If ATF has been added to a power steering system as in an emergency situation, the system should be drained, flushed and refilled with power steering fluid as soon as possible to avoid damage."
          Yeah don't use ATF. Use what the car recommends.
          • Z26-T
            • Apr 2008
            • 486
            doesnt syn trans fluid cost more than power steering fluid? o.O Just go buy power steering fluid so you don't have any problems. You wouldnt want to use coolant as engine oil now would you?
            • Fuel
              • Sep 2007
              • 29
              two completely different substances
