4t60E changes ?'s
  • germ
    • Mar 2004
    • 76
    4t60E changes ?'s
    ok, i need to know if there are any changes in the tranny from 1996 to 1998-1999?
    i have a 1996 that i need to get a new tranny for and build up. a local place i can get them from says the 1996 is not the same as a 1998 and that they will not guarantee it. the new tranny will be coming out of the same style car, i.e. monte carlo.
    they want $700 for a 1996 w/ 90k on it, and only$150 for a 1998 w/ 15k on it
    if there are differences, what are they? wiring? sensors? i am almost 100% sure if there are any changes, thats what it would be.
    any help would be great, thanks!
    • 9191
    I remember that there were like 6-7 different versions of the 4T60E in just 94 alone, so I'm sure that there are some differences between the 2 you are looking at.
    • 4spdz34
      • 185
      i will look it up on si for u and let u know
      • dykz34
        • Jan 2004
        • 793
        I think that what motor the tranny was connected to also makes a difference. IE: 3.4 DOHC, 3100, 3800, etc. Can you find out that information?
        • 4spdz34
          • 185
          yes what motor it is connected to makes a difference. here is alot of stuff long read.
          they go in order, so the 1st trans model has all the 1st slot stuff. this should help. thanks to gm service info
          THIS IS FOR 1998 MODEL YEAR
          Transmission Model
          8AHW
          8CUW
          8YAW
          8BSW
          Vehicle Series
          W
          N
          U
          N
          Engine Displacement
          3.1L
          2.4L
          3.4L
          3.1L
          Engine RPO Code
          L82
          LD9
          LA1
          L82
          Engine VIN Code
          M
          T
          E
          M
          Overall Axle Ratio
          3.29
          2.42
          3.29
          2.93
          Final Drive Ratio
          3.29
          3.05
          3.29
          3.29
          Drive/Driven Sprocket Teeth
          35/35
          33/37
          35/35
          37/33
          VSS Rotor Teeth
          30
          30
          30
          30
          Final Drive Assembly
          STD
          FP
          FP
          FP
          Output Shaft
          STD
          STD
          STD
          STD
          Torque Converter K-factor
          180
          203
          163
          140
          Converter Clutch
          TCC
          TCC
          TCC
          TCC
          Case Side Cover Pan
          SSC
          SSC
          STEEL
          SSC
          SSC Mount Bolt Pattern
          4 BOLT
          6 BOLT
          4 BOLT
          6 BOLT
          Transmission Vent Assembly
          CAP
          TUBE
          CAP
          TUBE
          Temperature Sensor
          391
          N/A
          391
          391
          1-2 Accumulator Valve (Primary)
          INVERT
          STD
          STD
          STD
          1-2 Accumulator Piston
          136C
          136A
          136A
          136A
          1-2 Accumulator Spring(s)
          139A,B
          139A
          139A
          139A
          2-3 Accumulator Piston
          136A
          136A
          136A
          136A
          2-3 Accumulator Spring(s)
          138A,B
          138A,B
          138A,B
          138A,B
          3-4 Accumulator Spring(s)
          423,4
          423,4
          423,4
          423,4
          Notes:
          FP = Fine Pitch
          HD = Heavy Duty
          N/A = Not Available
          SSC = Case Aluminum Structural Side Cover Pan
          STD = Standard
          STEEL = Stamped Steel Side Cover Pan
          VSS = Vehicle Speed Sensor
          K-factor = Torque converter numeric rating (combines stall speed and torque multiplication ratings)
          This chart does not identify all unique build items and this chart may be subject to change.
          THIS IS FOR 1996 BUT SHOULD BE THE SAME FOR ALL 60E'S
          Transmission Identification Information
          (1) Transmission ID Location
          (2) SRTA Tag Location
          (3) Hydra-Matic 4T60-E SRTA Tag
          (4) Model
          (5) Model Year (6 = 1996)
          (6) Control Number
          (7) Transmission
          ( Serial Number
          (9) Julian Date
          (10) Calendar Year (6 = 1996)
          (11) Hydra-Matic 4T60-E ID Tag
          (12) Model Year (6 = 1996)
          (13) Line Built (1 = Line 1; 2 = Line 2; 3 = Line 3; 4 = Line 4)
          (14) Transmission
          (15) Julian Date
          (16) Shift Built (A = First Shift; B = Second Shift; C = Third Shift)
          (17) Model
          (1 Serial Number in Base Code 31
          (19) W = Warren Plant
          (20) Hydra-Matic 4T60-E
          (21) Model
          (22) Transmission Vehicle Identification Number Location
          THIS IS FOR 1996 MODEL YEAR
          Model Build Information
          Table A
          Transmission Model
          6ACW
          6AFW
          6ASW
          6HBW
          6BSW
          Vehicle Series
          C,H
          W
          C,H
          W
          N
          Engine Displacement
          3.8l
          3.1L
          3.8L
          3.8L
          3.1L
          Engine RPO Code
          L36
          L82
          L36
          L36
          L82
          Engine VIN Code
          K
          M
          K
          K
          M
          Overall Axle Ratio
          3.06
          3.33
          2.84
          3.06
          2.93
          Final Drive Ratio
          3.06
          3.33
          2.84
          3.06
          3.29
          35/35
          35/35
          35/35
          35/35
          37/33
          VSS Rotor Teeth
          30
          30
          30
          30
          30
          STD
          STD
          STD
          STD
          FP
          Output Shaft
          STD
          STD
          STD
          STD
          STD
          163
          180
          122
          163
          140
          Converter Clutch
          TCC
          TCC
          TCC
          TCC
          TCC
          Case Side Cover Pan
          STEEL
          SSC
          STEEL
          SSC
          SSC
          N/A
          4 BOLT
          N/A
          4 BOLT
          6 BOLT
          CAP
          CAP
          CAP
          CAP
          TUBE
          Temperature Sensor
          391
          391
          391
          391
          391
          STD
          INVERT
          STD
          STD
          STD
          136B
          136C
          136B
          136B
          136A
          139A,D
          139A,C
          139A,D
          139A,D
          139A
          136A
          136A
          136A
          136A
          136A
          138A,B
          138A,B
          138A,B
          138A,B
          138A,B
          423,4,5
          423,4
          423,4,5
          423,4,5
          423,4
          Notes:
          FP = Fine Pitch
          HD = Heavy Duty
          N/A = Not Available
          STD = Standard
          Table B
          Transmission Model
          6BXW
          6CAW
          6CTW
          6CUW
          6PAW
          Vehicle Series
          H
          G
          G
          N
          A
          Engine Displacement
          3.8L
          3.8L
          3.8L
          2.4L
          3.1L
          Engine RPO Code
          L36
          L36
          L67
          LD9
          L82
          Engine VIN Code
          K
          K
          1
          T
          M
          Overall Axle Ratio
          3.06
          3.05
          2.93
          3.42
          2.97
          Final Drive Ratio
          3.06
          3.05
          3.29
          3.05
          3.33
          35/35
          35/35
          37/33
          33/37
          37/33
          VSS Rotor Teeth
          30
          30
          30
          30
          30
          STD
          FP
          FP,HD
          FP
          STD
          Output Shaft
          STD
          STD
          LONG
          STD
          STD
          163
          163
          163
          203
          140
          Converter Clutch
          TCC
          TCC
          TCC
          TCC
          TCC
          Case Side Cover Pan
          STEEL
          SSC
          SSC
          SSC
          STEEL
          N/A
          6 BOLT
          6 BOLT
          6 BOLT
          N/A
          CAP
          CAP
          CAP
          TUBE
          CAP
          Temperature Sensor
          391
          391
          450
          N/A
          391
          STD
          STD
          STD
          STD
          STD
          136B
          136B
          136A
          136A
          136B
          139A,D
          139A,D
          139A
          139A
          139A,D
          136A
          136A
          136A
          136A
          136A
          138A,B
          138A,B
          138A,B
          138A,B
          138A,B
          423,4,5
          423,4,5
          423,4
          423,4
          423,4
          Notes:
          FP = Fine Pitch
          HD = Heavy Duty
          N/A = Not Available
          STD = Standard
          Table C
          Transmission Model
          6PBW
          6PKW
          6WFW
          6YLW
          6YRW
          Vehicle Series
          W
          U
          L
          C,H
          H
          Engine Displacement
          3.4L
          3.4L
          3.1L
          3.8L
          3.8L
          Engine RPO Code
          LQ1
          LA1
          L82
          L67
          L67
          Engine VIN Code
          E
          M
          1
          1
          Overall Axle Ratio
          3.43
          3.29
          2.93
          2.93
          2.93
          Final Drive Ratio
          3.06
          3.29
          3.29
          3.29
          3.29
          33/37
          35/35
          37/33
          37/33
          37/33
          VSS Rotor Teeth
          30
          30
          30
          30
          30
          STD
          FP
          FP
          FP,HD
          FP,HD
          Output Shaft
          STD
          STD
          STD
          LONG
          LONG
          177
          163
          140
          163
          163
          Converter Clutch
          ECCC
          TCC
          TCC
          TCC
          TCC
          Case Side Cover Pan
          SSC
          STEEL
          SSC
          STEEL
          STEEL
          4 BOLT
          4 BOLT
          6 BOLT
          N/A
          N/A
          CAP
          CAP
          TUBE
          CAP
          CAP
          Temperature Sensor
          391
          391
          391
          450
          450
          STD
          STD
          STD
          STD
          STD
          136B
          136A
          136A
          136A
          136A
          139A,D
          139A
          139A
          139A
          139A
          136A
          136A
          136A
          136A
          136A
          138A,B
          138A,B
          138A,B
          138A,B
          138A,B
          423,4
          423,4
          423,4
          423,4
          423,4
          Notes:
          FP = Fine Pitch
          HD = Heavy Duty
          N/A = Not Available
          STD = Standard
          • 4spdz34
            • 185
            that trans identification pic didn't load up, i guess i would have to host it, anyone want to do that for me?
              • 9191
              Email or PM me and I can do it...
              • germ
                • Mar 2004
                • 76
                ok well, since i have no clue about trannies, the car is a 1996 3100 monte carlo (3400 swap done now), w-body, vin M i think. i know my fdr is 3.33 for sure
                and the shops tranny they have i know is from a 1998 monte carlo with a 3100. the other info i have no idea about
                can someone decipher this info for me since i have no clue what i am looking at
                • 4spdz34
                  • 185
                  that doesn't tell u wiring, but that trans the 1998 has a 3.29 final drive and bolts up the same and evrything. so it should work. i say use your internal trans harness
                  • germ
                    • Mar 2004
                    • 76
                    would the 3.29 cause any problems with the spedo or rpm gauge accuracy?
                    and like i said before, i am tranny stupid
                    a tranny has an internal wiring harness? so if i use 96's sensors and stuff, and wiring, then the only thing different will be the ratio right? what about the differential? i am going to have that diff turned into an LSD by Intense, would that be any different than using the 96's?
                    • 4spdz34
                      • 185
                      no as long as u use the sun gear from the differential u pick it will not matter. u will not notice a differnce between the to diffs. are u getting the trans rebuilt u could go with a 33/37 ratio chain to get a 3.73 final drive. it really wakes up the 3100/3400 u putting a stall in that trans? i can hook u up with one. if your interested pm me
                        • 9191
                        http://www.60degreev6.com/hlperf/60V...iles/4T60E.htm
                        If I can get more of those specs, I'd be happy to add them. I plan on putting this up on the site as soon as I get it all worked out (even if I don't have a complete listing).
                        • 4spdz34
                          • 185
                          i will get u some more specs and the chart on how to read the model number, all i can remeber right now is that the first digit is the year so 6=96 and 8=98
                            • 9191
                            Yeah... I wasn't too concerned on how to read the chart. Most people will find a tranny, look at the tag and then look at the chart. If it suits what they want, then they are happy.
