Removal of Valvebody 4T60E
  • Danspeed1
    • May 2006
    • 86
    Hello,
    Just wondering whats involved in removing the valve body in a 4T60E?
    Thanks,
    Dan
    make trans side cover accessable, either by dropping that side of the driveline down or removing it.
    1 Remove side cover
    2 Remove wiring harness from VB
    3 Remove pump housing
    4 Remove valve body
    If you've never gone into a 4t60e yet, I will suggest buying at ATSG book from ebay, it will help a lot telling you which bolts to remove and what to torque them to going back in. Its a little too much to explain in a post.
    • TurboGTU
      • 453
      That and some Trans assym grease. Helps keep those dam balls in place.
        good call, i forgot about that.
