ohhhh the slippage!
  • Coyote_Rage
    Wrench Jockey
    • Mar 2007
    • 115
    ohhhh the slippage!
    Well driving home today My trans started slipping BAD pulling away from a light. Pulled over checked fluid and its all good pink/level fine. started going again and I get a shudder in 1st, and a looooooooong shift into 2nd. 2nd to third was a bit long, and 3-4 was a little long. It held 4th no problem at 70mph 2k rpm. So what do you guys suggest?
  • grandprixgtp_91
    • Nov 2003
    • 758
    Well depending on the transmission, if its newer(1995 - up) it could be the PCS (pressure control soleniod), you would have to do a line pressure test to find out for sure though.
    Jake
