Found the culprit for trans failure
  • RedZMonte
    • Feb 2004
    • 1378
    So it appears that the trans cooler in the radiator broke and leaked coolant in the transmission and tranny fluid in the coolant.... What an amasing mess... So i drained the fluid and replaced the filter then going to get it flushed and do another filter and fluid again.... Hopefully it works a little better.... And ofcourse need a radiator.... What a PITA!
    Any thoughts... think it will be toast or might work out for me...?
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
    Hard to say, I caught mine when it happened, as the temp gauge was reading a little higher than normal, and so I checked the coolant level and found ATF in the coolant fill tank.. I dropped the pan and filter and flushed it put found no coolant in the trans, it was high enough pressure to not let it back flow and I caught it in time.
    The clutches are paper I think or something like that, and coolant and water destroy moving bearings/parts but who knows, you may luck out. Can't hurt to try I guess.
    • RedZMonte
      • Feb 2004
      • 1378
      Lol i do have a bit of clutch material in the pan.. on not optimistic. i think its going to be done for. got the car for $500 bux so not to bad of a deal.
      S
      Shane "RedZMonte"
      • turboD
        • Feb 2006
        • 37
        The problem is that the glue they use on the clutches, including the Torque Convertor Clutch is water soluble. Coolant damages the clutches first, then takes out the small bearings. Best to overhaul the unit and replace the torque convertor.
        Needless to say, you'll need to completely flush the cooling system also.
          I personally would just plug off the trans cooler holes in the radiator, forget the new one and buy an aftermarket trans cooler.
          • TurboGTU
            • 453
            x-2.
            • d.o.h.c
              • Jun 2004
              • 981
              Or do a 5-speed swap.
