I have a 98 4T65E stock with the exceptoin of the sprockets and chain for a 3.69 FDR. It has about 40K miles. I'd like to firm up the shifts for a nice bump over stock. I have complete control over line pressure, however, as I add more, the TCC lock becomes abrupt and jerks the car around. I do want to lower the line pressure some to help that, but not a whole lot. It this something I can do with my own parts to shim the accumulators, or should I shim and change the springs? The kits all talk about 1-2 and 2-3, but what about 3-4? Why not have that firmer too? There are several kits out there from $20-$130. The cheaper one has 2 springs and 4 different shims. The others vary springs and shims. I'd like to keep my kidneys intact, but would like that controlled snap when getting more on the gas. Any suggestions on what I really need? If you have done something like this on a 4T60/65E, let me know what you did and how it worked out. Thanks all!
Need help with shift kit choices
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Tags: None
Contact or search for threads by 3400-modifed. Shimming the accumulators will help a lot, and can make it shift hard enough to bark the tires but I think it won't affect your overall line pressure just how fast it shifts.sigpic
http://60degreev6.com/forum/f103/4t6...ift-kit-t39586
This is the most recent thread on the topic. Near the end it discusses the proper washers to use for shimming (IIRC).-Brad-
thanks Brad. good info. however, i found that i simply needed more line pressure. solved the 3-4 hang-n-bang and made everything nice and tight. she's shiftin wonderful!Andy
Yeah you got more control and options than I do, and they don't include the 3-4 with shift kits because well its overdrive, how often do you need a "quick" shift into that, and also that accumulator is under the channel plate so they don't expect you to be changing it with the others that can be done with a pan drop.
haha true! i'll need a quick wot 3-4 shift at 104 mph--hopefully in the quarter mile somday. i also have much more transmission than i can ever use right now. lighter car, less power and way more gear than a 98 Buick LeSabre. prob with the stock line pressure, i'll have the snappy shifts we all seek. i don't bark tires even on a 1-2 wot shift, but i've heard it scratch from time to time. now, if i could just get rid of that damn gear switch fail code! i still don't know how the hell my ECM knows when the TCC is locked!! the TCU is controlling the tranny now.Andy
What ecm and Bin file are you working with? and 3-4 at 104? What the? That seems low for 3.69 gearing... But I could be wrong, I was thinking more like 115 or something like that.
Just turn off the code and it will go away... especially if the TCU is controlling the trans now.
stock ecm and BFAH. 1-2 is 35 mph, and 2-3 is 65 mph. 104 mph is at 5100 rpm, the others are at 5200 rpm, unlike your 6000 rpm. remember, i have the MPFI with some bolt ons.
i have to find where to turn the code off. that's not in my bin or xdf files.Andy
Ah yes, forgot your still using that old motor...lol and yeah I shift at 6500-6600
haha yep! 154K and stronger than ever.Andy
well, i went racing and ended up somehow cracking the side cover by a bolt boss toward the bottom. since i'll have that much out, i might as well take the pan off and install a shift kit. just not sure which one to use. suggestions? i'm looking for a firm yet quick up/down shift that maybe won't chirp the tires at WOT, yet not too harsh for normal driving. suggestions?Andy
there aren't "shift kits" there are shift correction items, Gill Younger stuff would be a good start.
Gill Younger stuff?? say whaaaatt?Andy
Ok, sorry Trans Go parts... aka Gill Younger shift improvement kits...
4T65E Transmission problem codes P1811 and P0741 4T65E Transmission shift kit shift improvement kit Transgo & Shift kit Products on this site,4T65E Shift kit valve body kit
Thats your only "shift kit" choice and its not like the old 350 shift kits where you could choose a valve body plate to frim up the shifts.
