solid diff
  • Jbrogan
    • Oct 2006
    • 203
    solid diff
    what would happen if i just made a solid diff?? would it break anything in the trani when i turned or would it just hop a little?? i am having traction issues and just thought about doing it.
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
    the tires will squeel around corners at lower speeds.. at higher speeds you'll lose traction turning.. even worse in the rain/snow.
    LSD is the way to go if you drive it on the street...
    • 93grandprixse
      • Aug 2005
      • 35
      just please please please if your going to go solid use a spool or mini spool
      id recomend something like a quafe transmition, not so much limited slip, most of the times the clutches need to be replace frequently if you are racing with a limited slip...
      • Jbrogan
        • Oct 2006
        • 203
        spool or mini spool??
        1996 Beretta
        3100 SFI TURBO
        • Azrael
          Accelerating uphill in OD
          • Apr 2005
          • 763
          Spools are basically a solid piece of steel that replaces a diff. They're generally not recommended for anything outside of dragracing. They also add a huge amount of steering effort on a FWD car and a lot more treadwear.
          1995 Grand Am SE
            You should not lock a front wheel drive diff... end of story, unless you trailer the car to the track.
            If you drive it buy an EP LSD, it will make driving possible and also improve traction.
            • gectek
              Banned
              • Aug 2006
              • 1472
              The problem being, afaik they dont make a spool for a fwd style diff. you could prob modify a mini spool to work, but yah you would be breaking the output shafts right a left on the right and left, lol, due to all the added pressure and your tire trying to force its way faster than the inside tire. you could just weld the gears in the diff old school style, but thats not recommended either
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                Exactly. People wouldn't even weld the front in a 4X4 you can't turn worth shit. If you had any scrub radius in your steering system you would never be able to turn the wheel at all unless you were moving. And even when you were turning you would vastly increase the turning radius of the car making it very un practical. Then add in all the parts wear and breakage and you could easily pay for a pair of slicks for the track or a LSD.
                • Jbrogan
                  • Oct 2006
                  • 203
                  already got slicks and my problem is that one tire will break loose then the other back and forth until i get a ways down the track. i need at least an lsd.
                  1996 Beretta
                  3100 SFI TURBO
                    Then call or e-mail Jeff at Engineered Performance, your looking at 600+ or so for a LSD for a 4T60E setup($599 LSD cost unless winter sale of $499, not sure if he does that anymore, then 150+ for output shaft) the same style I'm using, machined steel plates and modified output shaft to resemble 4t65e style, No removable clip, it's like the axle clips that hold it in the diff making removal easy.
                    • loner666
                      • Oct 2006
                      • 435
                      Dont forget the unknown wait time. Thats one thing that stops me, among the fact that I dont have close to a grand to drop on a diff setup and I dont have a spare diff anymore (Sold it to a better cause. lol). I do need something though if I keep my setup. I really do hate the one wheel wonders and fighting the car the whole way down the track
                      Best 1/4mile ET - 12.9
                      Best 1/4mile MPH - 111
                      1997 Ford Ranger Splash
                      Daily Driver
                        Wait or break... some things are worth waiting for.
