anyone seen a G6 6 Speed mated to a gen 1 or any of our motors ? the citation group on yahoo showa guy that did it. very interesting.....
G6 6 Speed ?
hooking it up to the motor isn't that bad, its the same bolt pattern the 60*s have always used, its hooked up to a 3.9, which is a HV motor, meaning it'll be fine.
mounting it to the frame is another issue...
Yes, It does involve an amount fab. work, but it can be done for sure........1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
actually i remember seeing a 91-96 GP with the B4U(?) body kit that had it....
if i ever do get my monte converted over to a manual, the F40 is my choice.
you can even get them brand new for $250 somewhere, i just cant remember where though
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
yeah but who wants to keep shifting wit that close gear ratio? id rather stick with my stock v6 geared 282[SIGPIC]
12.268@117... 11's to come!
the easiest way to fix that would be to change the final drive ratio... but i don't know if thats possible.
i know with the 4t60e there are like 4 ratios to chose from but i don't know what you can do with manuals... especially since the f40 only went in 1 vehicle with 1 engine(not counting foreign stuff).
you don't have to shift gears in order. if you have enough torque, you can skip gears. i found that out while driving an RSX-S. for the city driving, i'd only use 2,4, and 6 gears and it did fine.Andy
1st gear that low would be great for bumper to bumper traffic.
no, Acura doesn't have GM's 6 spd. i used that example for comparison. that car...you shift A LOT in town. however, it has max power at about 8,000 rpm, so a close ratio gearbox is good. our lower rpm engines with so much more midrange torque, don't really need a close ratio tranny.
Andy
LOL, 3500. With my auto I'm turning like 2150 at 75mph. 3000 is where I start making good power, so with that 4spd manual, I'd never have to downshift to pass on the highway... LOLsigpic
