No 1st gear
  • fastback4
    • Feb 2009
    • 175
    No 1st gear
    1997 Monte Carlo LS auto 190,000 mi.
    Did a voltage check at the EGR valve electrical lead and accidently shorted 2 wires. Blew the PCM fuse, replaced fuse, now i have no first gear. Has reverse. Car accelerates in second, will shift to 3rd and then overdrive. Fluid is normal. Any suggestions to check?......Tom
    see if you actually killed the shift solenoid(or its wiring) that deals with 1st?
    • fastback4
      • Feb 2009
      • 175
      Where is the 1 gear shift solenoid located and can I test it with a volt meter?
      Tom
      • fastback4
        • Feb 2009
        • 175
        Whew! I disconnected the battery overnight, reconnected this morning and trans is shifting well. I suppose this reset the PCM thingy doodle brain box ect. ect. ect
        • torq455
          If I only had money!!!
          • 1615
          yes it did. may have gotten a little power to the ecm just before the fuses blew. sounds like you did a type of re-flash for the tranny. it's amazing how computers work and how a little accident can make one little thing not work.
          Andy
          fastest 1/8: 10.19@ 67.17
          fastest 1/4: 16.16@ 82.70
