I can remove my pcv tube fairly easy and also remove the rear valve cover without removing the plenum....... I can also do it without removing the ALT!
125c
Now this i'd like to see!Originally posted by 1988GTU View PostI can remove my pcv tube fairly easy and also remove the rear valve cover without removing the plenum....... I can also do it without removing the ALT!
There is no way you can remove the PVC in .5 second if it has that stupid riveted clamp on there.
What the hell is that all about?Last edited by asylummotorsports; 05-28-2009, 12:03 PM.
The pump behind that stamped cover it would be very easy access and make adjustments, providing you have clearanace. But I don't know what clearance you guys have on J and L bodies. I would like to think you can do it on the car. I know a longer intermediate servo pin should firm up the 1-2 as it will apply faster.Last edited by gpse3400; 05-28-2009, 09:15 PM.Lorenzo
