diff 4t60-4t65
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    diff 4t60-4t65
    I read both postings on the 4t60 to 4t65 diff. What was decided?
    I'm looking at getting a torsen for the 4t65e, part # 88958682.
    I looked at transtar catalog and it doesn't give a difference in the hard part diff, from 60-65, only ratio. GM Performance doesn't specify if the torsen diff is HD or not, which means I have no idea of what ratio it is, or if I have to worry about axle lengths like i read about.
    What I'm seeing in my research is a standard 65 diff should be a drop in to a standard 60. THe weirdo spline counts exempted.
  • torq455
    If I only had money!!!
    • 1615
    i do believe you are correct about the 60/65E diff being the same. the spiders are machined differently for the bigger axles on the 65E. i don't see why you should have to worry about axle lengths between the two.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
