3t40 and 3x00 kickdown
  • 6r8ph1X
    • May 2008
    • 14
    what do i use for the trans kick down cable when i'm doing a 3400 swap??? i'm doing a tce throttle body and i don't know how this is going to work. Asylum i need your help.
    setup is
    3400
    3t40
    Look for 94 3100 TB's. Steal the linkage shaft and swap in. Mine had a spot for a kick down cable...
    • 6r8ph1X
      • May 2008
      • 14
      for the 3 speed auto???are you sure? do you have any pics? please say you do.
        no, 3100 1994 4T60-E car. But the TB has a place for a kick down... Like when the TB opens, it would PULL a cable instead of a cable pulling the TB open....
        Look at that, see the top part, where a cable would go, then be rotated forward pulling the cable when the throttle cables pulled the bottom. Most early 3100 TB's have this linkage shaft.
        But not all brackets have a spot for the cable. Mine didn't, but I've seen I think even 97 grand am's have the linkage bracket with the spot cut out to hold the kick down cable...
        Just go to a junkyard with a lot of 3100's and look around. I'm sure this would work.
        If not some people use a throttle box from an old grand am auto LO Quad, but those I think are rare and a pain to hook up.
          WEAK strutbar....
          i believe the monte has the cut on the bracket...
            weak? It's square tube and welded... Not the ricer crap with heim joints that doesn't do anything... It made a huge difference...
              more of a joke than anything(statement, not the bar)
              i know mine helped more than new tires
