Ep lsd 4t45-e
  • nixtux
    • Nov 2007
    • 282
    Ep lsd 4t45-e
    I'm thinking about getting a EP LSD street, but only to improve traction on ice/snow. I was hoping to get some feedback.
    1999 Alero, 3500, 4t45-e 3.29fdr.
    I know with the 3400, it had issues keeping traction on dry pavement. Without traction control. Would LSD cause issues at higher speeds? Would the car to be more unstable on ice/snow at higher speeds? I would think it wouldn't be locked so it shouldn't make a difference. But it would add traction at lower speeds and at take off.
    The tires are fair, but not seasonals so I'm putting new seasonal tires on once the car is finished in a few weeks. I'm waiting on a cam/pushrods. So I have a few weeks to mess with other ideas while the transmission/motor are out of the car.
    • 9191
    Do you have a lead on an LSD that is currently available? If not, and you are going straight through Jeff at EP, then I wouldn't be worried about how it handles in snow/ice. At least not for this winter...
    • nixtux
      • Nov 2007
      • 282
      I was talking with Jeff at EP.
      • Azrael
        Accelerating uphill in OD
        • Apr 2005
        • 763
        If it's just for snow and ice traction than the phantomgrip or team green insert kits might be enough. They're cheaper and you'll get either a heck of a lot sooner. EP's LSD's are on a several months-long waiting list.
        1995 Grand Am SE
          i had the team green insert, it was excellent in the snow.
          • nixtux
            • Nov 2007
            • 282
            I sent a e-mail to them to get a time frame.
            Jeff quoted 7 days which would be okay since I won't have all the parts
            until at least the 9th. But if there is a waiting list months long that would
            be too long. I don't want to have to have the transmission tore out a few
            months from now.
            the snow.
            • nixtux
              • Nov 2007
              • 282
              The transmission shop I talked to said they wouldn't put the inserts in because the
              4t45e isn't designed to take any horsepower and the inserts would just burn the diff
              up after about a block so he wouldn't be willing to warranty the work.
              I guess the question is, are the inserts worth it and would anyone have a brief run
              down of the work required? I found a overview for a Getrag, but I'm not sure if a
              auto is really that different.
