i know this is a crazy long shot but do u guys know how possiable it would to to use a abs spped sensor as a second vss. i need two and even if it wouldnt be to exact i just need the pcm to know wen the cars stopped and moving. the tranny is a nvg282 and the cars a 99z24 idk if any one has more knowledge or might know the tooth count on a 282?
abs speed sensor as vss?
Newer cars use the ABS system to run the speedo and stuff, so I don't see why it couldn't work... What is your goal with this?-60v6's 2nd Jon M.
If you can change the speedometer constant in your tune, I don't see why not?
Hell I might do this cause I think the VSS tone ring is busted in my 282... LOLsigpic
