4t60e Performance Rebuild kit.
    replied
    Originally posted by RedZMonte View Post
    I thought all the DOHC trans had the same... 3.29 rings a bell but i have to check.. I did F Up the stock diff (long story....... Spinning on ice..... Hooked up.... No mas bueno) so i had a spare diff from my '92 when i did the L67 swap, so IIRC im running a '92 Z34 diff..
    S
    Then you would probably have a 3.33 version. 92's were 3.33's and such. It wasn't till 95 they introduced the 3.29 and then changed the gear cut again in 96, so there are two versions of the 3.29 diff that are not interchangeable.
  • RedZMonte
    replied
    S
    replied
    What is the code on your trans? you may have a 3.29 diff, which in that case the sun gear cut angle and pitch is much different and that alone might have solved and issue that these other non fine pitch gears had... the 2.84 3.06 and 3.33
    They went back and forth if your not familiar with it.
    94 and older were the regular cut, regular pitch.
    in some 95s, not all they introduced a new group of reverse cut, fine pitch diffs
    and in most 96's but once again not all they took the same group of diffs and made them regular cut again but kept the fine pitch
    the straggles of both years 95 and 96 use the 94 and older style setup, there are three configurations in my book for 97 that used the 94 and older gear's... 98 and 99 have none listed.
    Its been like that up till the end, and into the 65e's With these changes the final drive carrier was also updated to a different gear to match, And then in 96 they introduced the new 1-2 roller with the inner cam, vs the outer one. This also changed the final drive ring gear to have different oil holes on the shaft.
  • RedZMonte
    replied
    Here is a 4T60-E hard final drive sun gear (about 10 pages down... near the end) bit is only for the 30 tooth version (3.33 Gear)... I don't know what mine is 30 tooth, 34 tooth?.... Anyone?
    "Upon rebuilding the 4T60 transmissions the final drive sun gear is often found damaged. The helical gear teeth are often pitted and spalled under normal operation. This damage can be the result of overstressing, poor lubrication, or incorrect hardness depth. If the damaged sun gear is not replaced, the planet gears will also become damaged and the entire planetary assembly will need to be replaced. There are three OEM gear ratios: 2.84 (38-teeth), 3.06 (34-teeth), 3.33 (30 teeth). This gear is for the more popular 3.33 (30-teeth) applications only.
    This replacement final drive gear is made from ultra-high strength alloy steel hardened to a depth appropriate to withstand high tooth loads. Teeth are crowned to improve lubrication and longevity. This is truly a better quality gear than the OEM gear at an aftermarket price. Cost $17.00"
    replied
    Hardened sun gear I'm not sure... I think 4t65e diffs are the same so if they make a hardened 65e one then I think you could get one of those, but I haven't seen a destroyed sun gear yet... It took loose parts in my diff housing to chip a tooth off... lol.
  • RedZMonte
    replied
    is there a hardend sun gear i should look for? i saw a company made on but i don't think it works with my gear ratio...
    WITT is listed as a autorized dealer for the raybestos clutches... Ohh sweet they are out of denver 45min from my house.
  • RedZMonte
    replied
    Thanks man! that helps clarify my questions. I wonder if i would need the 3rd gear Zpak, or if its overkill even for my turbo setup..? my tranny guy is good, only guy i trust doing any work on my car. if something is wrong he has allways made it right by me (not to often has it been returned unresoved).
    S
    replied
    Ok, I'll try to answer all of those.
    Valves: They are all stock replacement but improved upon... Only one that MAY need work and a different valve is the TCC one, if its badly worn they make a reamer kit and oversized valve for it. Also these are NOT typically replaced.
    Hard parts: These are stock replacement parts yes, and both should be of a better quality than the original OEM. the 1 part listed as 96-99 yes is different than the older, with a 96+ the roller bearing for the axle shaft is ON the shaft itself, for the 95 and older there is a pressed in roller bearing inside the 4th clutch hub, both are offered in stronger versions, you would want the older one since I'm sure your splines are worn. Also on Bulkpart PN#A84570A 83-95
    Clutches: WIT and Raybestos I'm assuming are the same... I had not received a reply from them, but since Raybestos lists their part number under the same line labeled as their stage 1 kit, I can only assume its Raybestos clutches with a WIT specific number just for inventory purposes. The Zpak is a special 3rd gear only clutch pack that they sell... its supposed to be for very high horsepower applications. You can mix that in with the stage 1 kit by just leaving out all the third gear clutches and using the Zpak in its place. I was going to originally do a the Blue input pack, a stage 1 second pack, and a 3rd Zpak and a 4th Stage 1, but when I realized how much that was going to cost I figured I would try the stage 1 setup first... THEN upgrade later if even necessary.
    Steels: Yes you will need to get them when ordering clutches... Unless you buy a full deluxe rebuild kit, or one that lists it as coming with steels. This whole list is of stuff that I'm using in my trans, not necessarily what every person needs. I had to argue with Level 10 to have them send me a set of steels and all bands since I thought their price for the kit was insanely high for not including those items.
    Kits: YES GET THIS KIT! You want to install this on ANY 4t60e you rebuild, It will help prevent some of its big flaws. It is only ~$60
    Rebuild Kit: Yes these steels will probably be just fine, just remember the Deluxe kit comes with a set of stock replacement clutches too, so your kinda over buying... unless price wise it works out cheaper to get this full kit plus just the stage 1 fiber kit and sub those in.
    Thrust washer Kit: Yes these are typically replaced in any rebuild since they come with most of the full rebuild kits. Some people will only replace the worn ones too, but I do all depending on age of the trans.
    Good luck and I hope your mechanic is a good one
  • RedZMonte
    replied
    Few questions.... My Mechanic is rebuilding the trans (GM Tec for 15+ years.... he has rebuilt about a bazillion of these 4T60's).. Sorry for the retarded Newb Tranny questions.. I just want to make sure i get the list of things i want replaced with non stock '95 parts is correct.
    Valves: are these items that are normally service/replaced when rebuilding. Are the parts you listed stock replacement parts or different in some way?
    Hard Parts: Are the parts you listed stock replacement parts or different in some way? I see the 2nd part you listed is "Hardend" so i assume its stronger then stock, and the 1st part is listed for 96-99 are they different then the 95 and prior...
    Clutches: WIT and Raybestos are the same parts or should i get them from Raybestos? Whats the Zpak?
    Steels: I assume i should get them when i order the clutches? anything special about these steels?
    Kits: Worth getting?
    Rebuild kit: the deuxe kit includes steels and front band, will these steels be fine or should i get the other steels?
    Thrust washer kit and Misc items, Bushing, Bands: assume these are all just standard parts and my mechanic will know to replace them when he rebuilds?
    Sprags: Self expanitory..
    Thanks for your help...
    replied
    OK... Big list here... and hopefully a good update for those who want to know what’s fully done to my trans.
    Parts list:
    Valves: Purchased from http://www.transmissionpartsusa.com
    84754-22k Torque converter clutch apply valve kit (standard size) 91-96
    84754-23K Anti-stick 1-2 shift valve
    84754-25K hi-ratio Reverse & modulated line boost kit
    84754-36k 2-3 Shift Valve 94-97
    84754-37k 3-2 Downshift valve 91-up
    84754-38k 3-4 Shift valve 91-up
    84754-39k 4-3 Downshift valve 91-up
    Hard Parts: Purchased from http://www.bulkpart.com
    A84570B 4th Clutch hub & Shaft (No bearing at clutch hub end/Sleeve race at splined end) 96-99
    A84624 Shell, Reverse Reaction, Black Hardened
    Clutches: Purchased from http://www.level10.com (I recommend http://www.wittrans.com for others, MUCH cheaper)
    84119EAS1 (wittrans number) Friction Module Stage 1 95-up (Raybestos Part #RCPS-32)
    Steels: Can be purchased from http://www.wittrans.com (I got mine from level10 after complaining)
    84139EA Steel Module, L94-UP
    Kits: Purchased from http://www.transmissionpartsusa.com
    37936 4t60e Transmission Shift Kit, 1991-1999 (Shift Improver/correction kit, NOT PERFORMANCE)
    Rebuild kit: Mine came with level10 Kit, I recommend this for others http://www.transmissionpartsusa.com Or second FULL kit from http://www.northernautoparts.com
    37023 Transmission soft Overhaul kit 91-99 (No bonded Pistons, No steels, No fibers) Soft kit, Gaskets, o-rings, sealing rings.
    84008EA TranStar Deluxe Rebuild kit (includes Pistons, steels, fibers, front band, and filter)
    Bands: Can be purchased at http://www.Bulkpart.com
    A84026A 1st & 2nd (Center Band) 1-2 Coast 91-up
    B84022E FWD (Rear band) 91-up
    B84024A Reverse (Front Band) 91-up
    Bushing Kit: Can be purchased at http://www.Bulkpart.com
    84030E Bushing Kit 91-up
    Thrust washer kit and Misc items: Purchased from http://www.transmissionpartsusa.com
    37670A 4t60e Thrust Washer kit 93-up
    84532-01k Differential Lube Tube Retainer
    84881 Solid pump slide pivot Pin (pack of 5)
    4662 Transmission Pump vane (9 needed)
    37954 3rd Clutch Bonded Rubber Piston 91-99 (If needed)
    37953 2nd clutch Bonded Rubber Piston 91-99 (I would suggest replacing during rebuild)
    37888 4t60e Dual red strip vacuum Modulator 83-99 (Universal Adjustable type)
    Sprags: MUST REPLACE STOCK on 95-older http://www.bulkpart.com
    A44654 1991-1995 1-2 Roller (springs rub inner race and burn out causing failure.)
    A84652A 1-2 Roller 1996-up (Factory one typically lasts just fine.)
    Now everything that has been done to my trans has been done in an odd fashion…
    I first purchased a Deluxe rebuild kit from Northern Auto which included all the bonded pistons for the apply clutches, two bands, and more, Part Number #84008EA… The piston are not always needed since they don’t wear out that often and most of the apply pistons have lip seals which come in the soft kit. Also when I purchased this full kit it contained the full bushing kit so I did not have to purchase this separate, I listed all the items separate above because if you buy a full kit you waste money on a set of clutches you won’t use. I didn’t do the math, but if you get a full kit that comes with steels and bushings pistons, and bands (if noted) then you may save some money over buying all individual. I only recently did the Stage 1 kit from Level 10 where I'm replacing all the clutches and steels, and replacing my bands since I found a burnt one, and also putting in all new seals since I'm in there, I'm leaving the bushings alone since they look just fine.
    I hope to get some pics up later.
    replied
    I need call a trans place first to see of the stage one kit they offer is the raybestos one, then I can get up a full list of the parts needed and the place to buy them from. I have our season opener race tomorrow so hopefully I'll get that info up on Monday.
  • RedZMonte
    replied
    Will it be too much to ask for a parts list of what your puttin in? My Trans just had epic FAIL and will know what the cause is early next week when my mechanic can get to it.. If it needs a rebuild i would definatly like to make it a little stronger.. it may be something we can put under the forum for future resourse
    Thanks in advance...
    Shane
    replied
    Yes But I'm using the strip version of all the packs right now, Rabyestos Stage 1 Reds, and I do not need to drop $60 on 10 clutch plates quite yet. 3800SC guys are frying STOCK clutch packs on a daily basis... I'm not doing stock ones, I'm just not going all out for the Z-pak.
    I'm sure the trans will come apart next year for a quick inspection, and if I show signs of the 3rd pack wearing or burning up then I will eat my hat, and get the Z-pak
  • TurboGTU
    replied
    Cool. Just remember that GM used stock packs on 1st and 2nd and went zpack on 3rd on its drag car. 3800sc guys fry thise on a daily car. Just saying.
    I know, trans rebuilds get pricy quick.
    replied
    Wow wait a minute here...
    I've rebuilt this trans once before... All Trans Go fixes have been applied including Accumulator pin replacement along with tough seals... I also did all the bushings when I rebuilt this once before, and they are still fine to this day since there is only about 14k on this rebuild.
    I've also already replaced the Reverse shell for the hardened one, and the 4th hub since the splines were worn on the original setup.
    There are no Teflon seals that the second drum can take out... I think your thinking of the driven sprocket support bushing, that has a taper to help the fit of the Teflon seals on the input/forward drum.
    Also what converter problem do you speak of? I never stated any issue. Unless your talking to WillyMan... He's been over my house and I've shown him what parts change through the years, and which ones are better.
    Also there is no adjustment on the packs... I get a set of steels and a set of fibers... They are all of a set thickness so the only way I could not have enough space is to have a wrong part in there. Mine are all preloaded with a wavy disk getting installed first, that takes up the slack but also leaves some to allow freewheel.
    The Z-pak is overkill for my application and I was told that by Raybestos themselves, so I'm not going to just listen to what performance shops say and what others who push the Z-pak. I had NO issues with third on this setup with stock clutches SO I can only assume I will not damage the Stage 1 kit. My only clutch issue was my input set, the rest looked good.
    IIRC a 4t60e does not require in/lbs for torque... All parts are of a ft/lb value, and I've done those before, so it's not new to me.
    And for the sprags, 1996+ low roller sprag is of a much better design and does not need to be replaced, I will take apart my input and third sprag once again to inspect them, but I think they will be fine and not need replacing as well. What I should have done is upgraded to the 65e ratchet sprags, but I'm cutting back on the money I'm spending and I've also reached my time limit and can not deal with another part delivery delay.
    I've got MUCH more into this trans than I did before, and it lasted 2 years then, and probably would have gone longer if I had left it, so I think I will be perfectly fine for now and maybe I can buy those other parts in later years and then when I do another trans I'll put those in.
