Anyone have 4T65E ID info past 06?
  • Joelfke
    • Mar 2010
    • 46
    Does anyone have ID info for 4t65e trannys post 06?
    only goes up to 06..
    In 06 they might have changed to the 6t40.
    Also if there is no info about it after 06 but they were still used, that may also mean there were no changes to the internals, so only the number on the tag would indicate the year difference but the setup would be the same as the 06 choices.
      if you want a specific year and model's 4T65E info, i should be able to get you up to 08. after that and my info well runs dry. and i know the last GPs still had the 65E, so they kept them until 08 at least...
        Yes but like the 4t60e went, they may have all been the same from 07-08... only one variation... it was like that in 1999 for the 60e, there was only one type out there, the 9AHW, and 98 there were only 4 versions... and the AHW was the same specs from 97-99 just the year prefix changed.
        • Joelfke
          • Mar 2010
          • 46
          i know they still use em because a guy at work just did one in an 08 impala....
          if the tag is the same minus the year then thats fine but i would think this would be common knowledge by now no?
            Yeah, but it depends on how old that page is, and if that individual even cares to update it... Might want to check on a GP board since most of the 65e's were mated to 90* v6's
