6/ 60 t-5 or t-56 bellhousing help
  • grnrdragon
    • Apr 2010
    • 46
    any one know what years and what vehicals with the a t-5 or prefared t-56 trans bellhouing had the starter bump on both sides? this would be an awsome info for anyone using a fwd motor in a rwd applaction.
    • 9190
    See if this helps...
    http://60degreev6.com/forum/showthre...D-Bellhousings
      T56 isn't going to happen unless you can find someone to make an aftermarket bellhousing.
      The T5 info is in the thread above, however the T5 won't handle much power. That's why i went with a 700R4 instead.
      • RedBird
        Aka Mr. 5th Motor
        • Sep 2006
        • 426
        depends on what T-5 you're going to use. a decent condition V8 T-5 should hold most V6 swaps(including yours, you quitter lol). if that's not good enough, if you want to drop a little money, you can pick up some nice aftermarket T-5's.... if i ever swap my engine into a RWD project it'll get the v6 bellhousing and a T-5.
        Cammed 3400 --> 224whp 210wtq
        Cammed 3500 --> ???
        1 of 5 3500 J-Bodies
          interestingly, today this link popped up on TGO...
          may have some use for you.
            T5's are either WC (World Class) or NWC (Non World Class). the NWC ones are junk, the WC is a little better but still can't handle much.
            4th gen Fbodies got the WC T5's behind the V6's but it wouldn't hold up to the LT1 or LS1.
            I wonder what manual trans the 5th gen V6 Camaros are getting... I bet it's a beast.
            • grnrdragon
              • Apr 2010
              • 46
              okay more info here. 83' -94' isuzu troopers with the 2.8l and 5 speed have the starter on the drivers side could be used. camaro / firebirds same years Im told have the starter bump on both sides. anyone good at fabing can make these bellhouseing work on a t-56. if not any good at machine work should take the bellhouseing and trans to a good shop.
              • Monzsta
                • Jul 2007
                • 132
                D&D had a T-56 trans and adapter plate that replaced the T5. Just find/use a 60* t5 bellousing and the adapter plate and trans.
                '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
                1/8 mile 9.72@75 mph, 2.0 60 foot
