does any one know of any mounts that will bolt a 95 olds 4t60e in to a cavalier my cavalier is a 02 and had a ecotec with 4t60e but the mount is diffrent just cheekin to see if anyone knew of a mount that will work befor i pull out the welder and make something work
transmission mount is diffrent need help
Tags: None
the top two bolts are the same but the way the cavalier mount is the lower dont mach and the mount sticks out from the trans
heres how the lower holes are
heres the cavalier mount
an 02 cavalier would have a 4T40 IIRC, not a 4T60.
i have seen come custom mounts made before, but i can't remember where.
well after i looked at the two mounts and mest with the car and the trans a little this is what i came up with what do you all thank
stock jbody mount
moded w body mount trimed off were it bolted to sub frame and welded the center part of jbody mount to it
and now my w-j mod trans mount all done
