Whats the difference in the Getrag 282 and 284 ? Is the 282 a 4spd ?
Getrag Tranny .. 284/282
Tags: None
the 282 is a 5 speed for Cavaliers, I believe it's only supposed to bolt up to the 3.1... I could be wrong though. I think it's just a weaker version of the 284 made for the Cavalier.--Rob
The 284 was made for the 3.4 DOHC engine, only used in w-body's, and only used from 91-93. Its so much stronger, uses a pull style clutch, and has gearing meant for a DOHC motor.
The 282 is much smaller (50lbs lighter). It was introduced in the last years of the Fiero, used in the Cavilier and such, was on the w-body for 88-90. The NV5T40 (i think thats its name) that is used today is pretty much a 282.
since we are on the subject of he getrags, i was gonna try to put one in my 91 GP 3.1, so are you implying that i would not want the one out of a cav, that i should try to find on outta a wbody, or would the others work, keep in mind, i got some engine work done...
Someone asked about the torque ratings for the Getrag 284? I've heard 250lbs/ft.--Rob
HM-282 was made Up to 89? 90?
external slave with slave pivot External to the case
91-92 they were NVG 5TM40
external hydraulic slave with the slave pivot point IN the bellhousing
and 93-94 was the NVG T550
interenal slave
2000 was the introduction to the New Getrag Transmission, weak buggers. ive seen a few bad mojo's with them. that and the horrid anoying "gear rattle" issue with them too.
IMHO just as lame as the Ishitzu's.Colin
I hate to tell ya'll... and I only know this because I work at a Chrysler dealership as a job.... but the getrag 284 was used in the late 80's in the Chrysler TC by Maseratti behind the 2.2l Turbo II engines. I beleive it was 1989.... i can check my catalogue. I did price one one day, just out of curiosity.... almost 7k! OUCH1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
1962 Buick Electra 225 STOCK... and gonna keep it that way
