manual trans?
  • Shane
    • Aug 2010
    • 121
    manual trans?
    what cars in the 60 degree family came manual? and can they all be used on any 60 degree? like for example i wanna put a 3900 in my beretta can i use any 60 deg 5 speed?
    a list should be made and stickied of all mtx and what cars they came from
  • Shane
    • Aug 2010
    • 121
    lol. i love how helpful this forum is. sorry i dont know as much as you guys do. and my questions might seem dumb to you. we cant all be geniuses like you. if we were we would not need this page now would we.
      • 9187
      All cars with the 60v6 came with a manual prior to 94. Between 94 and 2006ish, there were no manuals available. Around 06, a 5-spd became available for a couple of years. More recently (08 ?), a 6-spd has become available. Off the top of my head, I'm not sure if any of the older ones will bolt up to a 3900 w/o an adapter plate. I think they will. I know some of the newer motors (3.6 DOHC comes to mind) don't share the same bellhousing pattern as the typical 60v6.
      Droid via Tapatalk
        LOL, patience... the only FWD 60V6 cars that had a manual transmission(i'm thinking of 282s, 284s, and F40s) were early A-bodies, L-bodies, J-bodies, W-bodies, the 2006-2008 G6, if there are more i can't think of them at the moment. the fiero used FWD transaxles as well but obviously is RWD.
        now the problem with using transaxles from other platforms is mounting issues, since most platforms used entirely different mounts. the A and W mounts LOOK to be similar/the same, while the J and L look to be either similar or the same, but it would be best to grab a trans from whatever platform you want to deal with to remove additional fab time. the G6 F40 is relatively on it's own since the last 60V6 with a manual trans before it was the 94 3.1 J-bodies.
        • Shane
          • Aug 2010
          • 121
          any idea what newer cars came with it? and will say one from a 91 cavi 3.1 mount to a 3900? And i have no idea what those #'s mean. lol!
          ok i was just wikipedia and what about the getrag F23?
            • 9187
            To find out more about FWD trannies hooked up to various engines, check out GM Powertrain archives: http://archives.media.gm.com/us/gm/e...pig_index.html
              • 9187
              I wouldn't use it, since its rated for less than a 3100 is rated at in stock form, let alone a 3900.
              Code:
              Type:  	                        transverse front wheel drive, five-speed manual transaxle
              Engine range: 	                2.2L - 2.4L DOHC (M86/MG3)
              Maximum engine torque:          155 lb-ft (210 Nm)
              Maximum gearbox torque: 	170 lb-ft (230 Nm)
                IIRC, GM rates max torque by the beefiest engine it was attached to. not to mention vehicle weight and traction also plays into longevity.
                that being said, i'd still avoid it.
                • Shane
                  • Aug 2010
                  • 121
                  ok so the 6 speed that came with the G6 would be best. but what would be 2nd best? everyone wants alot of money 4 the 6 speed.
                    i wouldn't say that... i've seen the 2006 specific F40 brand-new in box for less than $400 and they're only an hour drive away from me...
                    the 07-up revision is still expensive as hell though.
                    2nd best would be the getrag 284 as found in the 91-93 W-bodies equipped with LQ1 motors, but those are also not cheap, not to mention basically unrebuildable.
                    • Joseph Upson
                      Every tranny that bolts to the 2.8L will bolt to the 3900, the same for the flywheel although the engine is neutrally balanced. Most F40s I've seen for sale are around $500 shipped in the U.S. and brand new. That's a pretty good deal for that tranny. Anything you can find by Muncie and "Getraggedy" in the latest year possible for these engines should be better than the old Fiero versions standing up behind V8s and 3800s. Stop worrying until you break one.
                      F40s have been around since about 2003 on the Saab 9-3 which uses a different bellhousing and gear ratios.
                      • Shane
                        • Aug 2010
                        • 121
                        i have been trying to find one i can't?
                        • Joseph Upson
                          2006 or 07 pontiac G6
                          • Shane
                            • Aug 2010
                            • 121
                            closest one is 3hrs away andthey want $1000. what other cars came 3900 mtx?
                              • 9187
                              Do a nationwide search. Schram Auto up in Michigan has 3 of them, each with 1 mile on them, for $500. There were more for lower prices as well, those ones just stood out. Shipping isn't going to be all that much - figure $150 or so for freight.
