94 3.4 grand prix gtp trans compatability
  • E.S.
    • Dec 2010
    • 20
    The transmission in my prix is going bad. When checking the yards they are claiming only a 4t60e from a 94 or 95 3.4 car will work. Anyone know the reason behind this? I understand there is a difference in the gearing. But is there a physical or electronic difference betweena 3.1 tranny and a 3.4?
    IIRC, you should be able to use any 94-96 LQ1 4T60E, and any W-Body 3100 4T60E from 1993-1999.
    the gearing difference is absolutely minimal, 3.43 compared to 3.33 FDR. the torque converters also stall within 30 RPM of each other.
    ideally though, any 94-95 3.4 or 93-95 W-body 3100 trans will quite literally drop in place with no worries about anything being different.
    • gpse3400
      • 1460
      Technically he could but the pwm soleniod was added to the TCC circuit in '94. '91-'93 did not have that... not that you need it... The early ones also had some pressure switches, but the '94+ did not use them...
      Lorenzo
        actually, every 4T60E from 91 and up used the PWM operated TCC, except for the 91-93 LQ1 and 93-94 LH0 applications. and the pressure switches from the early ones? they're actually shifter position indicators.
        • E.S.
          • Dec 2010
          • 20
          Actually I believe they were saying something about a mount being different. I'll check back with them later today.
          • gpse3400
            • 1460
            Yes I am only talking of the 60V6 applications.
            Lorenzo
