Internal Slave Cylinder Leak
  • stevn94
    • Jun 2011
    • 3
    Hey Guys, Iam a newbie, Names Steve.. 1994 Cavalier Z24 5 spd 3400 swap
    Long story Short i Replaced the Internal Slave cylinder 3 times Now!!!!! Dorman brand, Warrenty. the last time i replaced the master Cylinder,,, Everytime it leaks within 50 kms of driving. Now I had the flywheel resufaced when i did the Engine swap thats when this all started... Should i have added a Shim between the crankshaft and flywheel after resufacing??? Also the 3400 came with a dounut washer installed infront of the flexplate for the auto trans ,Should i install this in front of the manual flywheel or lose it?? Somethings Has to be causing this????? I can't see getting three bad parts in a row???? This time the part store gave me my money back on told me to take a hike?? So this time i ordered a wagner brand Slave!!!
  • Barry
    95 Beretta LG8 Action
    • Aug 2007
    • 269
    I too had a brand new one start leaking (I forget the brand). I replaced it with a GM one with over 100k on it and all seems well so far.
    As for shims, I use a small shim (.020 maybe?) and my flywheel has been ground at least twice. Shims are not very important for internal slave cars. You would need to have a crap load of meat shaved off your flywheel to allow the slave to over extend and leak.
    I understand that you are probably really pissed, I was when I had to pull my tranny for a part that I bought new, just so I wouldn't have to replace it.
    95 Beretta- Lg8 Daily Driver
    • gpse3400
      • 1460
      Dorman is not the greatest.
      Lorenzo
      • stevn94
        • Jun 2011
        • 3
        Hey, So Got it all together Last night,,Sure enough Just after Bleeding, It started Leaking and lost all pedel pressure .Figures Didnt even get to drive it this time.. But anyways, I am planning to swap to a HM-282 (Getrag/Muncie) Used with the external slave Setup, Do i have to use the Flywheel off the car i Get the 282 From or can i use the one i have now off my NVG T550 from the 94. I Know it's a Different Clutch, Already ordered it. Just not to sure about the flywheel... Thanks
        • stevn94
          • Jun 2011
          • 3
          So i got the trans and release bearing from the scrap yard HM-282 Getrag/Muncie .. 1991 , i Bought a new release bearing , But the retainer spring that hold the fork tight against the release bearing was broken !! the new one didnt come with one i thought it would have, i cant find one anywhere gm discontinued ,parts stores list it !! Do i Really need it????? if so any idea where to find one??
