Quad 4 -> v6 tranny
  • bonecrrusher
    • 79
    Quad 4 -> v6 tranny
    Is there anyway I could use my 1990 Quad 4 GTZ HO tranny and just swap belhousings with a V6 tranny and use it? Because Ive got a perfectly good transmission, and it shifted very well before the motor blew. I know the gear ratios are very similiar, so Im thinking that this could work.
  • v6h.o.
    • 1418
    yup. thats all you need to do really. just swap front case halves. i'd check the proper shim in behind the diff bearing.
    in a 90 GTZ the ratio s are the same if its a regular Getrag trans such as a J/L body one.
    Colin
    • bonecrrusher
      • 79
      Yeah its a normal tranny, this should make my 3400 5 speed swap a bit cheaper.
      Should compliment my bilstiens, eibachs and poly upgrades that I'm currently doing nicely.
