t65e-hd bell housing interchang
  • gar70614
    • Oct 2008
    • 330
    Can I put the bellhousing ffrom a newer 05ish "tap-shift" transmission on a older non tapshift tranny. Like a 2002ish t65e-hd? Sorry if this is obvious I looked at some pictures and they didn't look to diffrent.
  • HOYS
    My posts are moderated
    • May 2010
    • 174
    The bell housing pattern is the same as long as you are using a 4T65E from a V6 application. V8 (LS4) application transmissions have a different bolt pattern IIRC.
    • gar70614
      • Oct 2008
      • 330
      i know the engine to trans pattern it the same (including the ls4 only with mounts for starter) but i was more curious about the bell housing to the trans if you get what im saying lol.
      • gar70614
        • Oct 2008
        • 330
        please ignore this thread lol i found more pics and the bell housing dosent seperate like i thought it did.
          • 9191
          That was kinda my thought, but thought that maybe the newer ones were. Oh well, glad you figured it out.
