Is it possible to spray clean the pressure plate and flywheel while installed? Or should I just take the massive anal reaming and pull the damn thing AGAIN......
First install it grabbed very well and would stall out in gear with brakes applied. Had it on stands at the time. Removed the block to fix a htob issue (air in the htob needed bench bled). After putting it all back together I am getting a terrible humming noise when I attempt to move the car under it's own power. Doesn't go anywhere, doesn't even rock the car any. Absolutely no motion when in gear and pedal is released but a terrible humming noise.
So I think the clutch is slipping pretty badly. The flywheel was cleaned due to a very light hue of rust. I am afraid the clutch still had contaminants when installed, or oil is leaking through the crank seal.
However, the front brakes are new and were grabbing the rotors very well during install. I always let them break free and seat with a spirited drive around the block.
Is it possible for front brakes locked to cause this? I would think the engine would stall out.
Ah man, if I got to pull that block again...................I got a headache now!
