Tranny Lines
  • tepes
    • Sep 2008
    • 23
    Tranny Lines
    need to replace rusty leaking tranny lines, need to change them from the tranny to the radiator, what size tubing and end connectors will i be needing.
    thank you.
    Moved to the transmission section so you get more views.
    • unchained01
      • Jan 2011
      • 388
      How about make and model of the vehicle etc? most are 3/8ths (9.525mm)
        Sorry, I moved it from the dohc maintenance section, so it's a 4t60e.
        • tepes
          • Sep 2008
          • 23
          1991 cutlass, 3.4 DOHC 4t60e.
          do i use brake line and bend myself? just trying to wrap my head around the best way to go about this.
          thanks in advance.
          • 1988GTU
            LB62LHObbqftmfw
            • Nov 2005
            • 2475
            Auto Parts for Your Vehicle at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.
            They should have replacement cooler lines in stock. Way better than trying to hodge podge it with hose, random line, and clamps.
