I was wondering if anyone knew the stall speed of the converter from a '94 Grand Am 3100 4T60E
Converter Stall Speed
1800?!?!?! I thought Chevy at least would get the same as like the Olds or pontiac w-bodies. My car's 2600Brian
3400 SFI V6, 4T60e
1800 doesn't suprise me at all. Although I'm not sure, I was told that mine was like 1898 or something like that...I don't know why they wouldn't just say its a 1900 though if it is.Originally posted by Rhedalert1800?!?!?! I thought Chevy at least would get the same as like the Olds or pontiac w-bodies. My car's 2600
Shawn90 Grand Prix STE 3.1 Intercooled Turbo-3100 Hybrid
99 Grand Prix GT
Quad or not...they should adapt to the 4t60(e). The TCLock up meterial is different though.
YOu can take advantage of a stalled converter with gears. No sence in runing 2500 stall on a 3.05 gear on a heavy car. The theory of stalled converter is to get as close to the engines peak tq. for better takeoffs. Pass the engines tq with a over stalled converter and performance will suffer alot. High stall with low gears(3.05) and on a heavy car and it will feel "jerky" or harsh. Not to mention the torque converter will heat up the trans oil faster. Just a caution.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
Yep, im well aware of that, I want a 2800 stall converter to complement my t65 build which will include 3.69 gearing. With a 3400 that should put me right where I want to be power wise at the launch. The trick will be learning how todo it with out braking the tires loose like mad. I still need alot of pratice launchingOriginally posted by TurboGTUQuad or not...they should adapt to the 4t60(e). The TCLock up meterial is different though.
1995 Monte Carlo LS
3400 SFI 60v6
what about the 4t40 or the 4t45, in the newer N bodys? I've got the 3.29 factory gear ratio. would that stall be to high?2002 Pontiac GrandAm GT1
3400 v6
TOG headers
RSM 62MM T-body
FFP underdrive pulley
GRANATELLI MAF
Ported upper intake
MSD DIS 4 ignition box
MSD Wires and coils (pending)
Venom high flow fuel pump (pending)
