Water in my transmission
  • SLC87
    • Nov 2014
    • 10
    Hey everyone,
    Radiator in my Maxx SS started leaking, so I installed a new one but unfortunately it was flawed, so I had to install the original until I got another replacement.
    Somehow in the process I must have screwed up my trans cooling loop because when I put the 2nd new radiator in, I had a bit of trans fluid in my coolant reservoir and my trans fluid was a bit milky. The car has a 4t65e
    It was only water thankfully, because I knew I was just going to redo it so I didnt use coolant. Just seeing what you guys think I should do and if any permanent damage is likely.
    I am planning on dropping the pan tomorrow, and doing 2 fluid exchanges and a filter change. Just curious If there is a better process like using the trans pump or a small (100gph) pump to flush it.
    The car drives completely fine if that helps.
    Thanks!
  • SLC87
    • Nov 2014
    • 10
    Alright, just an update for anyone with this issue.
    I did a pan drop on thursday. What came out looked like dark strawberry ice cream. I replaced with dex 6, drove it a bit.
    Today I dropped the pan again. We have upgraded to what looks like cherry syrup.
    Car still drives fine but it is looking like I will have to do 2 more pan drops and a filter change when I am satisfied.
    I have heard from a few shops that my transmission is toast and to expect it to fail on me soon. We shall see.
    No one but Jiffy Lube style places wanted to do a flush on it because it has over 60k on it, and said all they would do is a pan drop. So I figured I would do it myself.
    Kicking myself at this point, gonna be way more money in fluid and time than flushing it haha.
    • SLC87
      • Nov 2014
      • 10
      Dropped the pan again this morning and it still looks like it needs to be done again.
      Should of had Chevy do it with their flush machine I guess haha.
      • SLC87
        • Nov 2014
        • 10
        Ok, I just finished the 5th pan drop fluid exchange and am satisfied with how the fluid looks now.
        Just thought I would let everyone know.
