My '90 Cutlass has the 4T60 transaxle with the optional 3.33 final-drive. Can anyone tell me what the ratios are for each gear on this particular transmission? Also, what other final-drives were available on this car and what is gained by the 3.33 upgrade?
4T60 ratios and final-drive
\'90 Cutlass Supreme SL coupe - 3.1L LH0 V6/HM 4T60 -- every factory option
Flowmaster 40 - no cat // K&N FilterCharger // KYB GR-2\'s // Stant 180º SuperStat
Tags: None
I'm not looking for a better FDR, just interested in finding out what is gained by my 3.33 FDR over whatever was standard.\'90 Cutlass Supreme SL coupe - 3.1L LH0 V6/HM 4T60 -- every factory option
3.33 was standard for 4T60 as far as I knowOriginally posted by TeeJay3800I'm not looking for a better FDR, just interested in finding out what is gained by my 3.33 FDR over whatever was standard.Robby Whitesell
2006 Pontiac G6 GT
1985 Toyota Pickup DLX
Didnt I just say that?Originally posted by 4spdz34since you have a 3.33 that means your diff is 3.33 and your cahin ration is a 35/35. you need to get the chain and sprockets from a dohc trans which will have 37/33 ratio. and that will give you 3.73 with your diff
Anyways, the 3.33 is no better than any other diff.
