I was wondering if a transmission in a 1994 S-10 2.2L would match up to a 3100 or 3400 Camaro engine. If not a 3400 what about the vortec 4.3L.
S10 Transmission
Yes, the 94-95 2.2L I4 S10 gearbox will fit up to a 60 degree V6, but only if using the 1993-1995 Camaro bellhousing due to the "Ford" style bolt pattern on the front of the gearbox/bellhousing.
This will leave you with a tilted gearbox.... If using the 2.2L S10 bellhousing, the starter pocket is on the drivers side- incorrect for the RWD motor starter location.
-BMC.MG & MGB V6 + V8 Engine Conversion Shop
1982 Chevrolet S10 long box with another L32 SFI!
1980 MGB with Camaro L32 3.4L SFI V6
2000 Venture 3400 (for her)
Spitfire L32 3.4L
"Experimentals"
and more conversions all the time.
