4T60-E Differences....
  • Cliff8928
    • 532
    Ok, so a friend of mine has a 3400 in his Z26, and the car has went through TWO 4T60-Es first one being the original 2.97? and the second being a 3.33
    For the next one i suggested the one from the DOHC (being a little heavier duty), BUT one thing i need to know is what years of transmissions interchange?
    The car is a 1994... Can the trans used be any 91-97 transmission?
    Cliff Scott
    89 BerettaGT
    89 Volvo740
    Cliff Scott
    89 BerettaGT
    04 AleroGX
    • 9191
    There are 4 different internal variations of the 4T60Es. Let's see if I can remember what they are...
    Ok, I can't find the diagrams that I remember seeing the 4, but here is some info I found (from a 1991 ASTG rebuild manual):
    Buick and Cadillac trannies used a PWM solenoid, while Chevrolet trannies used a 4th CL Discrete and LO Discrete switches. This changes what pins are what on the connector. I remember that other differences were also temp or pressure switches, depending on the models.
    • Cliff8928
      • 532
      hmm... it seems hard to find some of this info.... I found some fairly good info here-
      but it's kinda dated and doesn't go over anything newer than 95 really....
      it does however specifically say that 3.4s don't have a PWM solenoid.... Anyone know if a stock 94 Beretta does? (you got a factory service manual Brad?)
      Cliff Scott
      89 BerettaGT
      89 Volvo740
      Cliff Scott
      89 BerettaGT
      04 AleroGX
      • Rhedalert
        Dr. Feelgood
        • 1574
        so what would a '95ish A body have? (Ciera) I got one of these and it's missing a lot of things normally seen in the w-body 60-E. Cant think right noiw Im half askleep
        Brian
        3400 SFI V6, 4T60e
          • 9191
          Yeah, my tranny uses the PWM solenoid. I think I remember where I saw the diagrams now... time to go see if I can actually find it!
          Hmm... so I was wrong. I'll have to look through my manuals again to see what I can find. I have my 94 Beretta service manual, as well as a 4T60-E Technician's Manual, a 4T60-E Electronics Manual and the 4T60-E ATSG Rebuild Manual.
            • 9191
            Ok, now I found them....
            • Rhedalert
              Dr. Feelgood
              • 1574
              awesome info!! I need to verify which one I have, and see if the w-body ecm will even control it. Thanks!
              Brian
              3400 SFI V6, 4T60e
                • 9191
                You need a 16149396 ECM to be able to control the 4T60-E. The '4396 ECM is identical to the 7727/7730 ECMs except that it has an additional 256k of RAM dedicated to the tranny controls.
                • Rhedalert
                  Dr. Feelgood
                  • 1574
                  I mean the w-body (16149396) ecm controlling a 4T60E from another platform, like the A body.
                  Brian
                  3400 SFI V6, 4T60e
                  • Cliff8928
                    • 532
                    Hrmmm... so what year DOHC tranny would match up the best to the 94 Beretta's ECM? (do they change in 96-97 at all?)
                    Anyone know what would happen if you used a non-PWM trans in a car that expects the PWM?
                    OR - can the PWM and related electronics be switched over?
                    Cliff Scott
                    89 BerettaGT
                    89 Volvo740
                    Cliff Scott
                    89 BerettaGT
                    04 AleroGX
                    • Cliff8928
                      • 532
                      Oh - and what do "CLW" "PCW" "PHW and "CMW" mean (some ID tag on the trans?)
                      Cliff Scott
                      89 BerettaGT
                      89 Volvo740
                      Cliff Scott
                      89 BerettaGT
                      04 AleroGX
                        • 9191
                        I was running my 4T60-E off of a 91 DOHC '9396 ECM without any issues that I remember. Well, I don't think I had OD (which was odd), but it might have been because we never messed with the code for the tranny. I might still have all the pin numbering I used to go between the ECM and the stock 94 wiring if that would help.
                        • Cliff8928
                          • 532
                          Well, the only change will be the trans, but still using the original ECM... if you have any info on that, it would be great...
                          is there any better year trans to get?
                          Cliff Scott
                          89 BerettaGT
                          89 Volvo740
                          Cliff Scott
                          89 BerettaGT
                          04 AleroGX
                            • 9191
                            Yeah, that's what I figured you meant AFTER I posted my message...
                            • Rhedalert
                              Dr. Feelgood
                              • 1574
                              unfortunately my trans connector doesnt match any of the diagrams above. I have:
                              A- Lt green
                              B- yel/black
                              C-brown
                              D-Tan/black
                              E-Pink
                              F- Yellow/black (again?)
                              G- black
                              Brian
                              3400 SFI V6, 4T60e
