282 - what do these parts do?
  • Z2_4cams
    • 147
    ok here you're looking at a piss poor diagram of what's underneath the shift shaft cover, you know, that cover at the front that points slightly downward.
    ok number one is the shift shaft, pictured without the spring.
    it has a lever off it (that piece going down towards #2) then 2 is a little pin thing, that limitsthe travel of the shift shaft.
    #3 is a piece that springs up and down, seemingly to allow the pin (2) to go over under certain conditions.
    my q is WTF do #2 and 3 do? the transmission seems to shift fine without the pin in that lever. and with the pin out the piece #3 is redundant right?
    say #2 and #3were to be damaged, os the pin is no longer in and the piece no longer can retreat into the case.
    is it screwed then?[/img]
    1989 Z24 3.1/3400 hybrid
    14.13@96.69 N/a slick full interior
    maybe my \"dreams\" should be a little higher :P
  • Quinky
    • May 2004
    • 159
    actual pictures are worth a 1000 words.. I love to help you out but I can't make heads or tails of whats happening..
    • ko0t3rskkar
      • 39
      It could be the reverse lockout, so you cant go straight from 5th gear to reverse by accident.
      1989 Chevy Corsica LTZ
      2.8L 60° v6
      5 speed
      • v6h.o.
        • 1418
        ? Chris get a real picture of what your talking about.... its too early in the morning to try and comprehend what you are trying to picture.
        However... IF its in that transmission, its htere for a reason, dont fuck with it.
        Colin
        • Will'sFiero
          Too many valves
          • 276
          Been a while since I had my box that far apart (or my spare box that far together)
          Take a pic of it... that should jog my memory.
          The spring under #1 is the 5-R bias spring. I do know that...
          I know 282's are purported to have reverse lockouts, but I've never run across one that did...
          Current:
          \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
          \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
          \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
          Gone, mostly forgotten:
          \'90 Pontiac 6000 SE AWD: slow but invisible
