282 gearing by RPO
  • Will'sFiero
    Too many valves
    • 276
    282 gearing by RPO
    In the 282 article section, there is this info:
    Quad 4 Getrag 89 1st...3.50 2nd...2.19 3rd...1.38 4th...1.03 5th...0.72 FDR...3.61
    1990 1st 3.50 2nd 2.19 3rd 1.38 4th 1.03 5th 0.81 Axle 3.61
    1991 1st 3.77 2nd 2.19 3rd 1.38 4th 1.03 5th 0.81 Axle 3.61
    1992-1994 1st 3.50 2nd 2.05 3rd 1.38 4th 1.03 5th 0.72 Axle 3.94
    1991-1993 W41 1st 3.50 2nd 2.05 3rd 1.38 4th 1.03 5th 0.81 Axle 3.94
    Isuzu L-Body 1st 3.73 2nd 2.15 3rd 1.33 4th 0.92 5th 0.74 Axle 3.83 V6
    Getrag All years J and L body 1st 3.50 2nd 2.05 3rd 1.38 4th 0.94 5th 0.72 Axle 3.61
    W Body V6 1st...3.77 2nd...2.19 3rd...1.38 4th...1.03 5th....0.81 FDR...3.61
    What are the RPO's for the various transmissions?
    MG2 was used in Fieros and with V6's. It had 3.50 first, 2.05 2nd, 1.38 third, 0.94 fourth and 0.72 fifth with 3.61 FD.
    The MV5 (I think) was used in W41's and has 3.50/2.05/1.38/1.02/0.81/3.94
    The MY5 (I think) was the W-body 5 speed with 3.77/2.19/1.38/1.03/0.81/3.61
    I don't know what RPO's the other transmissions had. Does anyone?
    I think that a project I have in mind would work best with the '89 Q4 gearset listed above, but I'd have to put the conventional bellhousing onto it. But I don't know what RPO transmission to look for. Any help?
    Current:
    \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
    \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
    \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
    Gone, mostly forgotten:
    \'90 Pontiac 6000 SE AWD: slow but invisible
  • TurboSedan
    • Jun 2004
    • 218
    i know my old '88 Corsica 2.8/5-speed was MG2....
    '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
    '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
    GM W-body Forums
    • Will'sFiero
      Too many valves
      • 276
      The vast majority of V6's were MG2...
      The only ones that weren't had the "W-body V6" gearing above... I think that gearset only came in the Cutlass, not the Grand Prix
      Current:
      • v6h.o.
        • 1418
        i dont know about the 89 version Q4 Transmission But the MV5 Equipped with FX1 Final Drive Ratio RPO Code is the 92-93 And still some94's 2.3L H.O. and 2.3L "W41" Transmission's with:
        1st 3.50
        2nd 2.05
        3rd 1.38
        4th 1.03
        5th 0.81
        Axle 3.94
        Colin
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          See this page for RPO's
          • Cliff8928
            • 532
            A while back i was at the dealer inquiring about the availability of a trans for the 1994 3.1 J-Body and they asked me if the final drive was a 3.61 (Which is the normal one) or a 3.43 or something like that. Anyone here work at a dealer that can verify that one?
            Cliff Scott
            89 BerettaGT
            04 AleroGX
            89 Volvo740
            Cliff Scott
            89 BerettaGT
            04 AleroGX
            • v6h.o.
              • 1418
              the final drive for all V6 Jbody 5spd's was the 3.61:1, there were no other ratios for teh 5spd available.
              teh 3.45:1 was for the Isuzu 4cyl 5spd trans.
              Colin
              • Will'sFiero
                Too many valves
                • 276
                According to that site (which I won't take as gospel)...
                Acheiva Quad-4 1992-1994 NVG T550 (MY5/MV5)
                Calais Quad-4 1988-1991 Muncie 282 (MG2/MU1)
                Cutlass Supreme 1988-1990 Muncie 282 - 5TM40
                Silhouette 2.3 4 cylinder 1993-1996 NVG-T550 (MU1)
                Grand Am 1988-1994 Quad-4 Muncie 282 (MGs[2?]/MV5)
                Sunbird Turbo & V6 1987-1994 Getrag 282 (MG2)
                I've left out most of the MG2's, since those are so common. The Sunbird Turbo transmission is kind of interesting, though... That was the Brazilian OHC engine, which had a different bellhousing, I think.
                Current:
                • geoffinbc
                  • 5831
                  Yes from the different info I have gathered it is different. Was it not an Isuzu or Toyata engine that was used?
                  • Cliff8928
                    • 532
                    half of the transmission in my beretta came from a Sunbird Turbo. But it needs to be replaced again.
                    Cliff Scott
                    89 BerettaGT
                    04 AleroGX
                    89 Volvo740
                    Cliff Scott
                    89 BerettaGT
                    04 AleroGX
                    • Will'sFiero
                      Too many valves
                      • 276
                      Why does it need to be replaced? Are you that hard on transmissions?
                      You could just overhaul it...
                      Current:
