Trans for RWD DOHC
  • 5SpdGTP-91
    • Jun 2004
    • 34
    Trans for RWD DOHC
    What rear wheel drive manual transmission would be a direct bolt up to a DOHC? Don't ask why, I may be a little insane
  • pwmin
    • Aug 2004
    • 394
    i would bet that none would directly bolt up. i would do a T56 (f-body/corvette 6 sp.) but youll have to have a special bellhousing for it to bolt up. you are insane but thats something i would love to do to a triple white cutlass (small block though instead of dohc)
    91 GTP HM-284 GONE :(
    98 Spawn of Satan (L67 Regal)
    87 V10 SM-465/Mild 350
    06 Cobalt SS/SC GONE :(
      • 9191
      Any Camaro or S-10 tranny would bolt up, but the block would have to be drilled on the other side for the starter. There is at least 1 bellhousing out there that has starter pockets on both sides. Do a search for RWD/FWD/bellhousing and you will find all of your answers...
      • 5SpdGTP-91
        • Jun 2004
        • 34
        Would that camaro tranny have to be a 60V6?
        • sharkey
          • Jun 2004
          • 2061
          yes. the 660 motors use a small gm bolt pattern, so you need to use a rwd tranny from a 660 aplication.
          are you looking for a standard or auto??? your best bet is to find a camaro or a blazer and take everything you need.
