Referring to the FDR change on the main page...
  • wireman121
    • 29
    I am a little confused. Are these the instructions to do this to a 3.4L TDC? The reason I ask is because, in the list of cars that can donate parts:
    "To obtain the parts needed to have a 3.73:1 FDR You will need to have access to a 4T60-E from the following cars:
    '91-'96 GM W-cars ('93-'96 3.1-3100, possibly later 3100 Luminas up to '02, '91-'97 3.4 TDC), '94-'96 GM N body cars will actually do as well. "
    It mentions the 3.4 TDC as a car that can donate. Or does this mean that you need the whole trans from the 3.4 and just the other parts from the 3.1?
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    The way I understand, the 3.4 already has the correct Drive Chain Sprocket Ratio. All you need is the 3.1 or 3100 FDR. Which makes it easier. At least that is the case for my application.
    • wireman121
      • 29
      thats the way i understood it too, just wanted to make sure that it made sense the same way to someone else :-)
      Thanks
