eh, not so easy. got a junkyard part. had one wire that didn't go into the connector (mine goes in it), my MLPS has a built-in harness with two connectors. also, one of the connectors was diff. than my setup. Basically, i had to fix the part before it was useable..................to a tune of $30.
94 4T60-E sudden loss of O/D
1994 Oldsmobile Achieva (2002 3100 SFI)
Homemade ram-effect CAI
K&N cylinder filter
Poorboy Lowering Kit
Front STB
eh, no. hooked it upto a Snap-On scanner and watched the MLP sensor as i shifted thru the gears. the sensor would read 4th gear in many positions (including the Park position). however, it wouldn't read 4th with the selector in O/D.
Basically, replacing the MLP sensor on top of the tranny did the trick.1994 Oldsmobile Achieva (2002 3100 SFI)
K&N cylinder filter
Front STB
Thanks, just wondering, my 94 GTP is losing OD and won't lock up at any given time(doesn't seem to be a pattern), until I shut the engine off, and re-start it, but then it will do it again within a few miles.
I've replaced just about everything, except the MLPS.
if it's popping out, it's something else. if it won't go in, try the MLP switch. but get a junkyard part, which will be cheaper on you. if it's not your MLP switch, you won't be out much money vs. a new switch.1994 Oldsmobile Achieva (2002 3100 SFI)
K&N cylinder filter
Front STB
